01-07-2012, 04:39 AM
Member #21798
Rear Lower A Arm
The large bolt that goes through the rear lower A that goes into carrier bearing keeps backing out and once snapped. I was able to repair but new bolt keeps doing same thing. Any suggestions????
01-07-2012, 05:25 AM
Member #3687
Have you tried using thread locker? Permatex makes it in blue or red. Blue is medium strength and red is high strength. It's a liquid and only takes a couple drops. I recomend the blue. The part# is 24200. You can get it at most any parts store.
1995 GMC 1500 Ext. Cab Z71( new motor 3 yr warranty unlimited mileage, on the road again  )
2008 Pontiac Grand Prix
1996 400 Explorer 4x4( project purchased 12-30-11)
1995 425 4x4 Magnum
1998 Sportsman 500 4x4(parting out)
1999 Kawasaki 220 Bayou 2wd
01-07-2012, 05:29 AM
Member #3687
I forgot. Make sure threads are good. Also before applying loctite make sure bolt is clean.
01-07-2012, 06:41 AM
Member #21798
I have tried the blue, guess I'll move onto the red. I'm worried the the female threads are shot.
01-07-2012, 08:50 AM
Member #3687
Might be. If they are a helicoil kit might be what has to be done. They cost about $35 and up.
01-07-2012, 06:48 PM
Member #21798
Whats a helicoil and where would I get one. I assume its some thing that goes into the female threads but not sure.
01-08-2012, 07:58 AM
Member #3687
Helicoil kit is a rethread kit. You will use the drill bit size suggested on the package. Drill the hole larger. Make sure to drill straight. Tap the threads with the tap provided in the kit. Put some grease on the tap to help prevent metal shavings from getting everywhere. Back out occasionally and clean ap and put more grease on it. Then make sure hole is clean and free of debris using air or brake cleaner(starting fluid will also work). Then using the thread insert screw it into the threaded hole using the plastic insert tool provided in the kit. Use threadlocker on the insert. Then you are done.
You will need to determine the thread diameter and thread pitch and get that helicoil kit. You can buy the kits and most any parts store. For sure Carquest and NAPA.
01-09-2012, 03:34 PM
Member #21798
Hey thanks for the info on the helicoil kit cost me 25 buck from pep boys. Better than intalling a whole new carrier housing.
01-09-2012, 04:57 PM
Member #3687
Glad to help you out. That's a good price on a thread kit. Keep all the taps and t handle insert tool for later. If you ever need the thread inserts they are sold seperatly. Remember while drilling and tapping hold them straight.
01-10-2012, 04:00 AM
Member #21798
Thanks again for the help!! The metal bushing should guide me if the diameter large enough. If not wish me luck or it's a new carrier bearing for me.
1993 polaris 350 4x4 rear shock bushings, 1996 polaris atv service manual pdf download, 2001 trail boss rear shock bushing, 93 polaris rear shock part #, 96 polaris magnum shock help, atv polaris parts lower a arm, atv shock bushings, how to change 1996 polaris magnum 425 4x4 rear strut, how to lower suspension on 2001 polaris 90cc atv, how to replace rear brakes on 06 polaris magnum 425, polaris 350l rear shock bushings, polaris parts a-arm, polaris trail boss rear shock bushin, powered by vbulletin arm, powered by vbulletin lower control arms, replacing a rear a arm assembly polaris magnum, strut rebuild kit for a 1994 polaris 400l atv
