Old 01-12-2012, 04:02 AM
saz's Avatar
saz saz is offline
Member #18711
Front end overhaul needed?
I have a 07 500X2, and the tops of the tires are tipping in significantly. I am sure the ball joints need to be replaced, should I look into replacing the wheel bearings and springs also? I am going to be out of the states for a while so I will be able to save some money for parts and I would like to take care of it at one time. What else should I look for?
Old 01-12-2012, 04:09 AM
KICKER431's Avatar
Member #18006
The biggest problem in front tires I have found are the wheel bearings. Total PITA to change but worth the effort. Ball joints aren't a bad idea. While your into it that far make sure you give all the CV joints/boots a good looking at. I replaced my bearings only to notice as I was reassembling that I was spinning grease out of a torn CV boot. On closer inspection I ended up pulling it all back apart and replacing all 4 boots.
2004.5 Sportsman 700 EFI
2007 Sportsman 700 EFI
Old 01-12-2012, 04:14 AM
check all the above but probably front spring sag causing tires to lean, get some Hd's from EPI or highlifter
Old 01-13-2012, 07:58 AM
saz's Avatar
saz saz is offline
Member #18711
I have been looking around at some of the parts I was going to replace and I cannot find anywhere that will ship them for less than like $60 to AK. I may have to go through the dealer.
Old 01-14-2012, 04:52 AM
Cycle parts ware house, ? if you want springs look on Erlandson Performance
Old 01-21-2012, 01:26 PM
bakada's Avatar
Member #2821
I bought Polaris HD snow plow springs from the local dealer for $79. Cheaper than buying them on line when you add in the shipping.
atv front end suspension with wheels
do you grease the front wheel bearings on a polaris scrambler 500 4x4
do you grease the front wheel bearings on a polaris scrambler 500 4x4?
foot pegs for polaris atv 2 up seat
how to grease polaris wheel bearings
polaris atv front end clicks
polaris predator front end
polaris predator front end maintenance
polaris predator front sag
polaris predator front wheels like to pull
polaris scrambler front wheel bearing care
86' Trail Boss 250r Front struts needed!!! SuncrestSniper Polaris Trail Boss 6 09-24-2011 01:23 PM
Recommended Valvetrain Overhaul Interval JFoley001 Polaris Predator 2 09-20-2011 05:05 PM
engine overhaul Predasaurs Polaris Predator 5 01-01-2011 02:27 PM
scrambler front hub info needed fred398 ATV Repair and Maintenance 0 12-04-2010 11:09 AM
front end alignment info needed... Eric24 ATV Repair and Maintenance 2 05-04-2009 10:33 AM
