Front brake is linked to the front and rear calipers. About a 60/40 split of braking force to each end. If you followed the brake line down, it would run into a junction box that goes to the front and rear calipers.
I have tried numerous times to bleed the rear foot brake with no luck. Is there a trick that will help me? I can get it to grab a little but it want stop the atv very quick if at all at a slow roll.
