Old 01-18-2012, 11:00 AM
res2cue's Avatar
Member #15153
Exclamation Strut front end guys.....
I never knew there was a grease fitting on the lower strut for the ball joints on my 03 330 Magnum guess cause it was covered in caked on mud and never saw it.
We'll I do now after replacing both ball joints! When i finally got the old ones out they where bone dry inside...
...NOTE TO SELF and others, grease the ball joint fitting on the lower strut!
That is all
Old 01-18-2012, 11:08 AM
factionfx's Avatar
Member #20681
+1 on this. It is a lot of work to replace the ball joints. I hope to not have to do it again!
2012 Sportsman 500, Red.
how to replace grease fitting polaris strut
polaris 250 front strut replacement
polaris strut replacement
Front CV rubbing inside strut jaybird78 Polaris Sportsman 9 11-03-2011 03:03 AM
Can you guys help me out - Strut Measurment GaryDee ATV Repair and Maintenance 10 05-04-2011 07:25 PM
Front strut housing question forrest411 ATV Brakes & Suspension 3 04-22-2011 10:35 AM
92 Trailboss 350 4x4 Front Strut Replacement Mountain638 ATV Brakes & Suspension 7 11-28-2010 05:18 PM
Front Strut for 1996 Sportsman 400 18fisher Polaris Sportsman 8 06-24-2010 04:55 AM
