02-06-2012, 04:42 PM
Member #10066
I will keep that in mind, thanks again.
02-23-2012, 11:34 PM
Member #23274
Just a quick thing here guys. Oil based products are murder on rubber!!! I use spray graphite, plus the other stuff attracts dirt and grime. That is a definate cure for a"whiney"noise! My honey says that's why she has her own quad!!!!! Remember, grease is cheap, don't be afraid to use alot!!!
02-24-2012, 03:12 AM
Member #22713
I used a product called Fluid Film water does not penetrate this stuff and it is far better than WD40 will ever be. Worked like a charm.
2011 Sportman 500 HO - RedRocket
2011 Sportsman 400 HO -GreenHornet
 Love to Live ...Live to Ride....Polaris
02-24-2012, 06:44 AM
Member #11247
Fluid Film is the best stuff I have ever used. Just difficult to find, usually order it by the case because it isn't sold at retailers.
Sent from my SCH-I510 using Tapatalk
2011 Trail Boss - HIDs SOLD
02-24-2012, 07:56 AM
Member #17948
My buddy also just got a 2012 Sportsman 400 H.O. and it also makes that squeaking noise. Annoying as hell when I'm behind him, at first I thought something was wrong with my machine lol. I think its just from the suspension breaking in or something, but as others have said keep an eye on it and make sure everythings greased before you go out
2002 Polaris Sportsman 500 H.O. EBS
-EPI HD front springs
-Polaris f&r tube bumpers
-Polaris hand guards
-Grip and thumb warmers
-2000lb winch
-60" Cycle Country plow w/ 150lb down force kit
02-24-2012, 09:09 AM
Member #22713
Fluid film is great...I can buy it here in Canada at any hardware store. It is made in Canada. EH!!!
02-24-2012, 11:44 AM
Member #9235
I use a can of silicone spray. Got it at Home Depot. Drys but leaves a film of silicone. Its cured all kinds of noises.
02' Sportsman 500 HO
Warn 2500
25" Grim Reapers
GoldFinger lefty throttle
02-24-2012, 01:25 PM
Member #1958
Hmmm...grease is not an oil based product? I guess not if its synthetic. Problem is its hard to get grease on a bushing that has no zerk fitting without disassembling the control arms. Also the bushings are not rubber. They are plastic. Squirt a little WD on 'em and go riding.
02-24-2012, 02:07 PM
Member #14376
Originally Posted by factionfx
Interesting...the 2012 500 has 6 zerks on the rear, 3 on each side, for each pivot. None on the rear hub though.
I was disappointed there was not a zerk for the ball joints on the front
They make up for that on the XP's. My 850 has 19 zerks on it.
02-26-2012, 07:39 PM
Member #10066
Funny, I was reading this older post and see that "Fluid Film" comes highly recommended. So I did a google search to see how much this stuff costs and the availability of getting some. Well, I saw a picture of it and I said to myself "I have a can of that stuff in my work truck".
I was doing some electrical work on a used machine at a paint manufacturer and my boss had to go to the place where they had bought this used piece of equipment from. He came back to me with a can of the Fluid Film and said they bottle it at the place he went to and the guy that gave it to him said "It's like WD40 on steroids". So from what I am reading this stuff is really good. What are the odds of that happening? Sweet! Apparently Fluid Film is made here in California!
2001 polaris 500 ho atv problems with squeaking coming from front end, atv rear suspension noise, best atv suspension grease, can i oil or grease suspension of my trailblazer, grease for atv rubber bushings, grease points on a polaris preditor, greasing sportsman steering bushings, how do you grease the rear portsman 500 ho, polaris 400 ho front suspension guards, polaris 400 ho suspension noise and grease, polaris atv suspension lubrication, polaris predator 500 need a rear shock, polaris predator 500 rear shock rebuild, polaris predator 500 squeaky rear shock, polaris predator 500 squeaky shocks, polaris predator chassis lube, predator 500 suspension squeak, predator suspension squeak, sportsman 500 ho xp front suspension conversion, squeeking comming from rear of atv polaris
