Old 01-31-2012, 08:54 PM
Rooskey's Avatar
Member #22134
Squeeky Suspension
I just purhased a new Sportsman 400 HO and have noticed that the suspension constantly squeeks the entire time im riding. I checked all the grease fittings and they have all been greased well from the factory. Could it be in the springs? If any others have had a problem like this please chime in. Thanks
Old 02-03-2012, 05:45 AM
factionfx's Avatar
Member #20681
The grease fittings are not full from the factory, even though they have grease on the nipple.
I grease my bikes every time i ride them because I have had to put new bushings in a trail blazer before and it was NOT fun.
FYI, mine still squeaks at the top steering pivot; there is no grease zerk there, but I am going to look into putting one on it.
2012 Sportsman 500, Red.
Old 02-03-2012, 05:47 AM
sgtpatiolantern's Avatar
Member #19332
A buddy of mine had a terrible whining noise on his 400. He just started leaving her at home.
2011 Sportsman XP 850 EPS
Nicknamed "KATT" (Kickass All Terrain Toy)
Polaris Lock & Ride Front Storage Box
Polaris Lock & Ride Rear Storage Box
Polaris Deluxe Front Brush Guard
Polaris Deluxe Rear Brush Guard
Polaris Handle Bar Guards
Polaris Lock & Ride Back Rest
Polaris 3500lb Winch Kit
Polaris Winch Accessory Kit
Polaris Wireless Winch Remote
Polaris Trailerable ATV Cover
Polaris Hand Warmers
Polaris Thumb Warmer
GoPro HD Helmet Hero Camera
"I fire up the willing engine,
Responding with a roar.
Tires spitting gravel,
I commit my weekly crime..."
Old 02-03-2012, 05:52 AM
pathfinder's Avatar
Member #10066
I have the same problem somewhere in the rear suspension. Having trouble figuring where the squeak is coming from and I grease my zerks after every ride. I'm thinking it's coming from the upper arms that don't have the zerk fittings, but not sure. Annoying huh? Makes it sound like an old beat up wheeler, lol.
2010 Sportsman 500 HO
3 headlight mod (with relay)
rear rack extender
handguards
Warn XT25 winch
Ricochet arm guards(anodized black)
Polaris front & rear brushguards
LED tail lights www.autolumination.com
HID light kit http://www.theatvsuperstore.com/ATV-HID-Lights-s/54.htm
Old 02-03-2012, 06:13 AM
factionfx's Avatar
Member #20681
Interesting...the 2012 500 has 6 zerks on the rear, 3 on each side, for each pivot. None on the rear hub though.
I was disappointed there was not a zerk for the ball joints on the front
Old 02-03-2012, 07:05 AM
Member #1958
That's just new and very tight rubber bushings. Soak them all down good with WD40 or some other penetrating oil including the shock bushings and they'll quiet down.
Hey Sgtpatiolantern, I bet she wishes she'd kept her mouth shut now don't she.
Old 02-03-2012, 08:44 PM
pathfinder's Avatar
Member #10066
Mine only has 2 zerks, one on each side in the rear on the lower arms. They must have gotten some complaints about not enough grease fittings and ended up adding some.
rear rack extender
handguards
Warn XT25 winch
Old 02-03-2012, 10:08 PM
Rooskey's Avatar
Member #22134
I greased all the zerks tonight and the front has really quited down. I think the rear is coming from the rear hubs. To bad there is no zerks on those. Oh well ill just keep riding. Thanks for all the replies...
Old 02-05-2012, 09:32 PM
pathfinder's Avatar
Member #10066
Thanks polman, I used some WD40 on the bushings in the rear that made noise and now NO MORE NOISE!! That was an easy fix.
rear rack extender
handguards
Warn XT25 winch
Old 02-06-2012, 07:49 AM
Member #1958
Yeah pathfinder, sometimes its easy to overlook the simple things. If the WD40 doesn't last or dries out try a little regular motor oil from a squirt can for a more long lasting fix.
2001 polaris 500 ho atv problems with squeaking coming from front end
atv rear suspension noise
best atv suspension grease
can i oil or grease suspension of my trailblazer
grease for atv rubber bushings
grease points on a polaris preditor
greasing sportsman steering bushings
how do you grease the rear portsman 500 ho
polaris 400 ho front suspension guards
polaris 400 ho suspension noise and grease
polaris atv suspension lubrication
polaris predator 500 need a rear shock
polaris predator 500 rear shock rebuild
polaris predator 500 squeaky rear shock
polaris predator 500 squeaky shocks
polaris predator chassis lube
predator 500 suspension squeak
predator suspension squeak
sportsman 500 ho xp front suspension conversion
squeeking comming from rear of atv polaris
Stiff my suspension alex69cuba ATV General Discussion 6 11-21-2011 04:14 AM
2007 800 sportsman EFI really squeeky scott_r ATV Repair and Maintenance 2 08-26-2011 11:35 AM
Suspension Help TheBatJon Polaris Predator 13 04-28-2011 04:25 PM
suspension setups? Ta2edphreak Polaris Predator 3 04-22-2011 12:25 AM
550 xp suspension michaeltucker01 ATV Brakes & Suspension 10 01-08-2011 07:01 AM
