02-02-2012, 07:02 AM
Member #20385
need new springs
I want to get some new springs for the rear. Between the new tires and my fat ass, the tires rub a little when hitting dips. What are my choices? I have found references to Epi and highlifter are there any others?
2007 Sportsman 500 "Lil Mule"
02-02-2012, 08:05 AM
02-02-2012, 08:30 AM
Member #11566
If your ass is as fat as mine (6'3" 295lbs) you will like the heavy duty springs. Your atv will sit higher and in my opinion will handle better. I have EPI springs in the rear and heavy duty springs up front. The fronts are easy to swap out the rears you will definitely need a spring or strut compressor. I think if you just change the rear you will want to also change the fronts, in my opinion. This is the tool I used to install the rear springs, borrowed it from a friend, but I believe you can rent them from an auto parts store for a few bucks.
02-02-2012, 07:10 PM
Member #20385
Originally Posted by Mike B
If your ass is as fat as mine (6'3" 295lbs) .
yes it is 6'5" 265 lbs
02-03-2012, 05:42 AM
Member #20681
High lifter also makes a kit for your bike. I just put the highlifters on my 2012 500...I get to ride tomorrow, but now there is no sag in the rear end.
It took me about 3 hrs to do both rears with hand tools.
I will put the fronts on next week. Just ran out of time this week. I have pregressor adjusters on the front for now, turned them all the way up.
heavy duty polaris atv springs
