Old 02-07-2012, 08:09 AM
swanny297's Avatar
Member #22678
2011 Sportsman 500 HO Lift?????
Hey guys
Great forum, I am fairly new to the Polaris world, I have a 2011 that I bought new last year and mainly use it for hunting / recreational fun runs.
I would like to add a lift for a little more ground clearance, I will probably keep tires mostly stock as we hunt a lot of federal and state refuges (tire/lug size is regulated and can be a $500 ticket if caught out of reg's). I have searched and looked at a couple, highlifter and RDC. Highlifter states that the rear axle bar kit is required for their 2" lift but nothing is mentioned on the RDC 2" lift, since I don't plan to put mud tires on my ATV, can I do one of these lifts without axle modifications? How difficult are these to do by yourself?
Thanks - any and all feedback is welcome
Clint
Old 02-07-2012, 11:15 AM
jwk_007's Avatar
Member #22943
Welcome to the site. I'm new to riding myself just got a 2012 400 h.o.
2012 Sportsman 400 H.O. Boardwalk Blue Stock.
Old 02-07-2012, 11:52 AM
factionfx's Avatar
Member #20681
I highly recommend the high lifter springs. You will need the sprp-adapter spring adapters for the rears. They are cheapest on amazon.com. The adapter you will have to buy direct form highlifter.
for trail riding I have highlifter HD springs in the rear, turned up 2 clicks. I don't have the fronts installed yet; this is the project this week.
The stock springs fatigue and sag very quickly. I can't believe polaris sells them like that.
2012 Sportsman 500, Red.
Old 02-07-2012, 01:39 PM
kool_500HO's Avatar
Member #11710
My 2011 fit without the adapter kit... If you have the aluminum adjusters you dont need them
2011 Polaris Sportsman 500 HO
6000K HID's,Kimpex fender guards,foot pegs,rear seat,Polaris Front/Rear bumpers,2500lb winch,Handguards,ITP SS 12" 212 machined wheels,ITP Mudlite XL 26" tires,Highlifter springs Front/Rear,26" Outlaws,QSC clutch kit/Exhaust,UNI filter,Ricochet A-Arm guards...More coming soon...Kinda running out of stuff to buy though!
Old 02-08-2012, 05:11 AM
swanny297's Avatar
Member #22678
Thanks for the feedback, I may try the springs, the other reason is this past weekend I got in some water and I guess my spark plug boot wasn't secure and it stalled on me in a little current and water, so I was hoping a little more clearance would help, but in doing some research yesterday the Triangle stealth snorkel kit are now good for machines through 2012, so I may do the springs and snorkel kit, along with some die-electric grease around the spark plug.
Old 02-09-2012, 04:39 PM
lost cause's Avatar
Member #9763
If you plan on snorkeling your machine you also need to dielectric grease every electrical connection. Not just the spark plug boot. Also make sure when you install the kit that you silicon your airbox lid and inner belt box cover.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 02-10-2012, 05:40 AM
maverick11's Avatar
Member #3694
Superatv.com sells an ez-install 2" lift kit that will only take an hour to install. I take it on and off regularly and have had no drive system problems. If I had some money right now, I would go wit the HD springs.
Old 02-16-2012, 06:20 AM
Chas0218's Avatar
Member #19651
haha wish I saw this post first. I just made a post about a 2" lift I am putting on my 2011 sportsman 500. I bought it off ebay its an ATV engineering lift kit. I will take a bunch of pictures of the install and report back with any hiccups. I am assuming it won't give me much more ground clearance but I figured I needed a weekend project and figured for $40 shipped I won't complain. I will be adding high lifter springs in the near future just for a firmer ride and less roll in the corners.
$40.00 lift kit for polaris sportsman
2010 polaris 500 ho dies in water
2010 polaris sportsman 500 highlifter outlaws
2011 polaris sportsman 500 lift
2011 sportsman 500 ho
4 wheeler shops
atv engineering forums
forum atv engineering lift
home made lift sportsman 500
how can i lift my polaris sportsman 500
lift for 2011 sporstman 500
lifting polaris 500 ho
polaris 2011 lift forum
polaris 2011 sportsman 500 lift
polaris 500 ho lift kit
polaris 500 ho springs
polaris 500 monroe la
polaris sportsman 500 lift with itp mudlite xl 27s
polaris sportsman 500 snorkel kit
polaris sportsman gorilla lift install
Tires and lift on 2011 Sportsman 500 HO jazlee88 Polaris Sportsman 26 04-30-2012 05:27 PM
2011 800 lift muddbone ATV Performance Modifications 9 12-27-2011 09:58 AM
2011 SP 500 - lift,tire,rim ? MudLife500 ATV Wheels & Tires 10 08-30-2011 02:05 PM
New 3" lift on my 2011 550 xp wishiwasfishin Polaris XP 7 08-18-2011 01:53 PM
do i need a lift and spacers to make 27 inch tires fit on stock 2011 sportsman 500? solid_crimson ATV Wheels & Tires 2 03-24-2011 05:56 AM
