02-08-2012, 03:10 AM
Member #22874
01 scrambler 400 brakes
I bleed an bleed my brakes an still dont work only wen i pump the front brake one or two times . Thinkin it might be the front brake master cylinder?
02-08-2012, 04:42 AM
02-08-2012, 11:12 AM
Member #1234
souds like it is
02-23-2012, 11:39 PM
Member #23274
My procedure for bleeding by hand is to remove the line from the M.C. and bleed it first. Then work one side 'til you get fluid, then do the other side 'til fluid, then final bleeding. Air is your enemy here.
02-24-2012, 06:15 AM
Member #20962
Excuse my ignorance, but what other way is there to bleed the brakes other than by hand? I was unloading my Scrambler last week when, to my surprise, I had no brakes. I stopped within inches of my Jeep.
02-24-2012, 06:18 AM
Member #11494
Mighty vac available at any auto pats store and harbor freight. Works much better than a hand job. Hey wait that didn't sound right
2010 Sportsman 500 H.O.
are scrambler front and brake brakes different?, bleed brakes polaris atv, bleed brakes polaris scrambler, bleeding brakes on polaris atv, how to bleed brakes on a polaris atv, how to bleed brakes on polaris atv, how to bleed rear brakes on a polaris atv, how to bleed the front brakea on a 400 scrambler, polaris scrambler 400 bleed brakes, polaris scrambler brakes only work when pumped, polaris scrambler front brakes, scrambler bleed front brake, scrambler bleed front brakes, scrambler brake bleeding
