Old 02-08-2012, 08:02 AM
uncbub23's Avatar
Member #10610
Removing front strut and broke balljoint on 04 sportsman 500
So i have to remove my front strut from my 04 sportsman 500 because i was installing a new front axle and when I was trying to get the a-arm off the balljoint I pulled the ball through the plate and now i cant get the plate off. I have everything disconnected from the strut but how do I get it out of the top mounting plate? I tried to put a wrench on it but the spring just turns. I was thinking about welding a bolt on the broke balljoint to get it out is that a good idea? Thanks in advance for any help.
Old 02-08-2012, 08:20 AM
Member #1958
You have to hold the top of the strut shaft with a 3/8 wrench while turning the 3/4 nut to get the strut loose. Once you have the strut out and in a vice you'll need to apply some heat to the screws in the retaining plate to soften the thread locking compound applied to the threads at the factory. They should then come out easily if you use a GOOD screw driver bit that fits the screws correctly.
Old 02-08-2012, 02:17 PM
uncbub23's Avatar
Member #10610
thanks i'll give that a try
04 polaris balljoint plates
500 removing strut ball jt from a arm
a tool to take a ball joint out of a strut on a atv
atv polaris sportsman 500 ball joint
broken ball joint on polaris
front ball joint polaris 500
front strut polaris sportsman
how to pull ball joints out of a polaris 500
how to remove a broken ball joints from a polaris sportsman
how to replace a polaris sportsman 500 ball joint
installing ball joint [olaris 500
polaris sportsman 500 front strut
remove lower ball joint from strut polair
remove lower ball joint front strut polaris
remove strut on sportsman 400
removing broken atv ball joint
removing front struts from a polaris sportsman
replace front ball joint on 04 polaris sportsman 500
sportsman 500 strut removal
sportsman front strut removal
removing front diff. 04.5 400 sportsman musselmark ATV Repair and Maintenance 0 05-22-2011 04:53 AM
Removing front half shaft 2004 sportsman 500 MADMIKE Polaris Sportsman 8 12-29-2010 04:33 AM
2000 500 sportsman HELP front hub/strut/axle PLEASE HELP Heavy Sausage ATV Repair and Maintenance 9 11-15-2010 05:46 PM
Removing Front Clip 2002 sportsman 400 Nitro Polaris Sportsman 0 11-05-2010 01:56 PM
Front Strut for 1996 Sportsman 400 18fisher Polaris Sportsman 8 06-24-2010 04:55 AM
