how to stiffen up suspenison - Page 2 - Polaris ATV Forum
  #11 (permalink)
Old 04-11-2012, 05:55 PM
paulniskanen's Avatar
paulniskanen
Guest
Member #
Posts: n/a
Polaris used to have FOX struts available for your machine. I have had 3 sets of them. The are the best addition to a sportsman you can do. The part # is 2872030. DO NOT get the 2872031's they are to long and will mess up the CV joints. The fox's are nitrogen filled, we used to put about 175 psi in them and would get about 1 1/2 to 2 inches o lift out of them and the ride quality is amazing.
  #12 (permalink)
Old 04-11-2012, 06:10 PM
Sporty500HO's Avatar
Member #23233
Originally Posted by gtsum2 View Post
you can use a pipe wrench to adjust the rear shock preload. I am ordering HD springs this week, as my ride as 250 miles on it, and I the front end wants to sag already...it pushes and dives something terrible in the corners when riding hard.
Are you replacing the front and rear springs? Where are you getting them from? Let me know how the install goes on a newer bike. Thanks
I am here: http://tapatalk.com/map.php?y12okz
Sent from my iPhone 4s
2013 Polaris Ranger 800 Crew EPS
LE Blue Fire
  #13 (permalink)
Old 04-11-2012, 06:21 PM
KICKER431's Avatar
Member #18006
Forgot to mention, I got my springs from Thor at theatvsupertore.com. EPI HD's on all 4 corners. He did right by me and I am very happy with my new springs. Gonna put them to their first real good test this weekend
completely stock FOR NOW
26" Maxxis Bighorn 2.0
  #14 (permalink)
Old 04-11-2012, 06:31 PM
gtsum2's Avatar
Member #23200
I am going to do the fronts for now. I recently went up on the rear preload adjustments a couple notches in the rear, and it helped a bunch...I imagine when I do the HD front springs, i will likely have to increase the rear preload more (I am 6' 240). I will likely get the EPI ones from Thor...seems EPI makes the hi lifter ones, or so I have read...I assume they are all progressive springs (I hope so)?
  #15 (permalink)
Old 04-11-2012, 06:38 PM
CuzzinOlaf's Avatar
Member #23134
My ATV was used mainly to plow before I bought it and my front was definitely sagging. I think the springs helped A LOT. I added the stiffer springs in the rear because of the Wes two-up seat I bought. I haven't had the ATV out yet but hope to get a ride in this month sometime. I bought everything through Thor as well and went to his house to pick it up since he is close.
  #16 (permalink)
Old 04-12-2012, 05:35 PM
widow maker's Avatar
Member #10101
You could try ATViagra......
Being stupid is not a crime. You are free to go.
Si vis pacem para bellum
'07 Sportsman 500efi, Viper max 3000lb winch, Amsteel cable. Front brush guard, rear rack extender, rear Polaris brush guard, SS312 wheels, 26" Big Horn 2.0 tires, 3 headlight mod, Quadovator temp gauge and fan switch, hand guards, ATV dog seat
  #17 (permalink)
Old 04-13-2012, 07:32 AM
factionfx's Avatar
Member #20681
I highly recommend you order both front and rear springs at the same time. The bike won't handle correctly if you dont.
I have the highlifter HD springs on my 2012. EPI does not make a kit for 2011+ value when I emailed them in January.
2012 Sportsman 500, Red.
  #18 (permalink)
Old 04-13-2012, 10:18 AM
gtsum2's Avatar
Member #23200
You likely got a good point there. I am honestly shocked at how much my fronts are sagging with only 250 ish miles on it. I ordered a winch today, so that will increase the front weight as well and only make it worse. I like to trail ride aggressively, and the front end pushing and diving in corners, especially under hard braking, is not good at all. So I take it you got Hi Lifter's all around on yours? Dont I have to order some spacers or something to make them work on my 2012??
  #19 (permalink)
Old 04-13-2012, 12:05 PM
factionfx's Avatar
Member #20681
Yes; trust me I tried it. It appears you ride like I do; you will be well pleased with HD springs all around. I have my rears turned up 1 click for riding aggressively; I'm 220 lbs. Would suggest 2 clicks for small jumping (1-2ft of air).
I also ordered front "moose pregressors" adjusters for about $60 for the front. That way if springs ever go weak i can turn them up without taking the bike apart. found them on amazon too
Amazon.com is cheapest for the springs, and they are from a third party! I looked for a while.
I ordered the adapters direct from Highlifter. SPRP-ADAPTER is the part number i believe.
  #20 (permalink)
Old 04-13-2012, 02:33 PM
gtsum2's Avatar
Member #23200
faction - do I need the adapter kit for both fronts and rears??
2014 sportsman 570 how to stiffen front suspension
best rear shocks polaris 2004sportsman
easiest way to stiffen/raise the front end of a 2004 polaris 500 ho
front suspension stiffener for 2008 700 polaris ranger
how do i stiffen the fron suspension on my atv for a snow plow
how to stiffen suspension on 99 polaris sportsman
how to stiffen suspension on polaris ranger
how to stiffen up front end on a 400 polaris
how to stiffen up rear suspention on a polaris sportsman
polaris 500 springs efi 2006
polaris ranger heavy duty rear shocks
stiffin up front end on polaris sportsman
