Bleeding Brakes - Polaris ATV Forum
Old 02-17-2013, 03:38 PM
foxden's Avatar
Member #11705
Bleeding Brakes
Having a problem bleeding the front and mid brakes on my 93 Big boss 6X6. I have cleaned all the lines, replaced the pads and installed a NEW master cylinder. I have tried the traditional method of pumping the master and bleeding each caliper, used a mity vac and also dropped a line into a bottle of brake fluid while using the traditional method, but still cannot get any pressure. I have the machine on blocks so I can rotate the tires.While turning the front tires I can apply the brake, but it goes all the way to the handlebar, but the brakes do stop the tires. I just cannot figure out why I don't have more brake pressure on the Master Cylinder. The right side,Rear brake works fine. Any thoughts and/or advise would be greatly appreciated. I'm lost on this one. I have been reading here and other places that bleeding the brakes on these machines can really be a problem
Thanks in advance.
Old 02-17-2013, 09:16 PM
Old 02-18-2013, 07:15 PM
Trailblazer2004's Avatar
Member #34208
I have the same problem help
Old 02-18-2013, 07:21 PM
fishhooker's Avatar
Member #23647
I've had to reverse bleed sometimes if its air-locked. I've not had to do that to any Polaris units, but vehicles and other brands of atvs.
Old 02-23-2013, 04:57 AM
Try leaving lid off of master cylider while you bleed.
Old 02-23-2013, 08:54 AM
Muggzy's Avatar
Member #22054
On my '01 sportsman, there's an adjustment at the calipers to compensate for pad wear/caliper travel. Your caliper may be running out of travel.
Sent from my SCH-I535 using Tapatalk 2
'01 Polaris Sportsman 500 HO project (needs a 'lil TLC. OK, OK, a LOT of TLC)
My first 4WD ATV!
1" wheel spacers, 25" STI Black Diamond Tires, Front and rear storage with seat.
My other ride is a 2-stroke sport quad.
Old 09-13-2014, 12:44 AM
tigers2007's Avatar
Member #46492
I hate to wake a sleeping bear but I have a '89 Big Boss 4x6 and I have the exact same issue. I got it used very cheap and has only 50 miles on it (was at a state park for 25yrs and was never used...). I had to blow crud out of all of the lines as they were clogged. Had to buy two new master cylinders (each handle) as they were both destroyed beyond economical repair. New pair of CHICOM MC's cost me $70 from eBay. Right side (rear) works excellent and has good pressure. The left side (fronts and gearbox brake) are very very weak with the handle pulled all the way back. With it up on a jack you can spin the front tires and squeezing the brake handle it will stop but I can still turn the tires with my hands. The gearbox caliper/brake isn't strong enough to stop the force of the new belt with the weak pressure. I have tried a MityVac to suck new fluid in. I have even replace the left MC with a different brand new unit. I even installed the old unit that I rigged back up -- no matter what, it has very weak hydraulic pressure. Air in the four-way manifold? Any good tricks? I though I read here that I should unhook the calipers and squeeze the pistons out farther, compress them then re-install and then test the brakes.
02 polaris 700 how to bleed all brakes
bleeding atv brakes
bleeding atv front brakes
bleeding brakes on 2002 polaris sportsman 700
bleeding polaris 6x6 brakes
bleeding the brakes on polaris ranger 900
how to bleed brakes on 2004 polaris sportsman
how to bleed brakes on a 500 polaris 4 wheeler
polaris sportsman 335 bleed valve rear brakes
polaris sportsman 6x6 brake bleeding
polaris sportsman 850 front brake master cylinder problems fourms
problem bleeding front brakes on atv
Correct procedure for bleeding ALL the brakes prickle Polaris Sportsman 7 01-09-2013 01:42 PM
Bleeding Brakes foxden ATV Brakes & Suspension 3 12-28-2012 05:06 AM
Bleeding Brakes Question smc9696 Polaris Magnum 3 09-22-2010 08:48 AM
bleeding brakes on scrambler w/broken master cycl. 425whpsti ATV Repair and Maintenance 2 07-15-2010 11:00 PM
brake bleeding xpedition 425 schmity ATV Brakes & Suspension 3 03-25-2010 02:17 AM
