rear master cylinder bleeding question - Polaris ATV Forum
Old 03-29-2010, 06:18 PM
kling2001's Avatar
Member #3575
I'm replacing the rear master cylinder on a 2004 sportsman 500 h.o. atp.
The plunger stays in the cylinder, and the foot pedal flops up and down, so i figured that the plunger is corroded. I can pull it back out with pliers.
but wont come back out on its own.
My question is how should i go about bleeding the new master cylinder? Should i put it on the bike and use some plastic fittings and little hoses and feed the hose ends into the reservoir like bleeding a car master cylinder. and pump it to get the air bubbles out then quikly screw the lines on ?
Then bleed the calipers to get all the air out of the lines.
(This has the dual rear calipers because its the atp)
Thanks for any advice in advance.
Old 03-30-2010, 03:03 PM
4getful2's Avatar
Member #1234
yes ,you can bench bleed those with the resevoir on but, you still should bleed the rear pistons just to be sure to get all the air and dirt out.
keep a paper clip or a tiny drill bit handy to clean out the passages in the bleeder screws.
Old 03-30-2010, 08:26 PM
kling2001's Avatar
Member #3575
yeah i figured its pretty much straight forward, i just didnt wanna miss anything, or if anybody knew a easy way,
thanks for the response
Old 05-19-2010, 03:57 PM
kling2001's Avatar
Member #3575
ok, i figured out that you need to keep fluid in the handle bar reservoir, and in the rear reservoir, its a split system
Old 05-20-2010, 01:40 AM
elmerkit's Avatar
Member #3805
You can do that procedure. just make sure to flush all the fluids before using a new and fresh one to avoid contamination.
Old 05-23-2010, 04:22 PM
weedy's Avatar
Member #2147
Cover the bars and plastic to avoid spilling the fluid on your machine. The fluid will jack the paint ig it spills over wen the master is filled. It shouls bleed like a caliper on a car.
2005 SP 500
2004 SP 500
2002 SP 500-SOLD
2001 SP 500-TOTALED
2002 polaris sportsman 500 brake cylinder
2003 600 sportsman bleed rear brake
2005 polaris atp 500 ho master cylinder problems
2005 polaris sportsman rear brake master cylinder
bleeding brakes on a polaris 700
bleeding rear brake 96 polaris
how to bleed brakes on a 2001 sportsman 500
how to bleed brakes on polaris sportsman 500
installing parts on a polaris 500 sportsman 2004 master cylinder
polaris 500 dual sensing break bleeding
polaris rear brake bleeding
polaris sportsman 500 brake bleeding
Master Cylinder Bad, is this one rebuildable? PolarisOne ATV Brakes & Suspension 7 04-23-2010 05:17 PM
wanted front master cylinder bomberboat ATV Parts for Sale 3 01-15-2010 02:01 AM
Master cylinder justincsandbar Polaris Scrambler 2 12-12-2009 08:47 AM
How to replace master cylinder on Magnum 325? cdn_cajun ATV Repair and Maintenance 2 08-03-2009 10:01 PM
1998 Polaris Sportsman Master Cylinder Leaks Hutchinson01 ATV Repair and Maintenance 3 06-18-2009 08:54 AM
