Heavy Duty Spring - Polaris ATV Forum
Old 04-24-2013, 07:42 AM
emetzger's Avatar
Member #35798
Heavy Duty Spring
Can someone help answer 2 questions for me regarding heavy duty springs for my Polaris sportsman 500, year 2000?
I have a 40 gallon tank that I mounted off the far back of my quad. I fabbed a frame for it so I could still take my seat off. When the tank is full it is about 350 lbs on the back of the unit. Right now I have 2 factory springs on the back and they are bottomed out when in use. Here are my 2 questions:
1. Is there a spring rated heavier than the EPI spring?
2. Can I use a Polaris ranger spring which is rated at 250 lbs per inch. Will this fit on the Polaris sportsman shock?
Thanks,
Erik
Old 04-24-2013, 08:31 AM
Mike B's Avatar
Member #11566
I believe the High lifters have a higher spring rate, but if i remember correctly is was not very much.. maybe 5 lbs. I put HD's on mine, went with the EPI's because they came in black. Not sure if the ranger spring will fit. Thatís a lot of weight sitting way back there.
Mike B
Old 04-24-2013, 09:03 AM
emetzger's Avatar
Member #35798
Mike B,
Thanks for trying to answer my question. I'm hoping someone knows if a ranger spring will fit on my sportsman shock. I will settle for high lift or EPI spring and not use so much water but would prefer the strongest spring possible since I have so much weight back there. I'm even considering fabbing some type of 5th wheel on the back for support but have no idea where to start.
Erik
Old 04-24-2013, 12:42 PM
Mike B's Avatar
Member #11566
Maybe fab something up like this.
Old 04-24-2013, 12:43 PM
Mike B's Avatar
Member #11566
pictures.
Old 04-24-2013, 12:53 PM
Mike B's Avatar
Member #11566
The new HD springs should help a lot. Those are pretty old springs, if they are from 2000. I have a 2008, when I first got (used) it, it would bottom out with just me on it hitting some bumps. Although I'm 6'3" 290lbs. With the new spring it would compress maybe an inch awhile sitting on it. They have loosened up a little more over the last year. They compress about 2 inches when I'm just sitting on it now. If you swap out the rears rent a spring compressor to get them apart, makes life a lot easier. You may want to do the fronts right away also.
Old 04-24-2013, 01:04 PM
emetzger's Avatar
Member #35798
Mike,
Big help right there with that pic of the wheel.
Thank you,
Erik
Old 04-24-2013, 01:15 PM
Mike B's Avatar
Member #11566
I like the dual wheel one. Wish I could see how they let it swivel.
Old 04-24-2013, 04:29 PM
wheeler700's Avatar
Member #34040
Just put the tank on a small trailer..
2004 Sportsman 700 EFI
27/11/12 Mega Mayhems
Custom winch mounts frt & rear
QSC clutch kit
Epi hd springs
HSP exhaust
Equus temp guage
switchless overide
Old 04-24-2013, 05:59 PM
RVS Performance's Avatar
Member #29606
I'm picturing it hanging out back behind the rack? If so you are compounding the problem and springs aren't going to fix it no matter what you do. I like the little trailer idea.
2002 polaris ranger helper spring
2004 polaris 500 sportsman rear springs heavy
atv heavy duty shocks and springs
atv heavy duty springs
heavy duty springs for polaris sportsman
polaris heavy duty springs
polaris ranger 800 xp heavy duty rear springs
polaris ranger 900 heavy duty front springs
polaris ranger heavy duty shocks
polaris ranger heavy duty springs
polaris ranger heavy rear shocks
what is a good heavy duty front spring for a 2004 polaris sportsman 500
Advice on heavy duty bumper 2012 850 XP w/EPS Mick1064 Polaris XP 22 04-21-2013 03:40 PM
Heavy Duty Clutch for Magnum 500? firewhirl Polaris Magnum 1 09-16-2011 10:37 AM
Xplorer 300 heavy duty rear spring? trex ATV Brakes & Suspension 5 05-29-2011 01:52 PM
Super ATV Heavy Duty Axles Super ATV Super ATV 9 04-21-2011 02:44 AM
04 Sportsman Heavy Duty Springs??? 04sportsman ATV Brakes & Suspension 3 03-28-2011 03:33 PM
