Old 06-25-2010, 06:00 PM
bomberguy's Avatar
Member #5605
800 Brakes
Have a 06 800 Polaris. Rear brake does nothing so while trying to bleed it I messed up the front brakes. Did not know they were connected to front brakes as they have their own little reservoir. So now I have no brakes at all and bleeding them has not accomplished anything! Is their an order in which you bleed which brake first? I notice the rear caliper has 2 bleed screws while the front only have one. Any help would be appreciated.
Old 06-25-2010, 06:25 PM
nq526's Avatar
Member #5386
Wouldn't you bleed both at the same time? I don't know.
09 800 Sportsman Touring
Front & Rear brush guard
Rear rack extender
3500 Polaris winch
27" Zilla's
1" Wheel spacers all around
Old 06-27-2010, 05:19 AM
Member #1958
First of all do you have enough pads? Right bleeder is foot brake/rear only. fill resevior full and bleed it first till all air gone and fluid at proper level. Then fill front resevior full and bleed other brake system. Make sure to keep it full. You probably got air in the system by letting the resevior get too low. Once ya get all the air out you can simply bleed off excess fluid till you get proper level.
Old 06-27-2010, 05:44 AM
bomberguy's Avatar
Member #5605
800 Brakes
Thanks for answering! Pads are fine so I will try bleeding in that order.
Help Brakes Stevehi ATV Brakes & Suspension 3 11-21-2011 08:04 AM
04 atp 330 brakes NotQuik ATV Brakes & Suspension 1 05-24-2010 12:50 AM
brakes on 09 xp 550 kohen ATV Brakes & Suspension 2 05-03-2010 04:28 PM
brakes 09cjpol08 ATV Brakes & Suspension 2 01-07-2010 05:21 AM
brakes triefff Polaris Scrambler 2 12-18-2009 08:58 PM
