07-01-2010, 05:43 PM
Member #5711
Bleeder screw
The bleeder screw on my 93 Trail Boss 250 has sheared off flush. Does anyone have a good way to remove them--seems it may be in there and siezed.
Can the caliber be redrilled and a new screw added?
thanks before hand.
07-01-2010, 06:50 PM
07-01-2010, 07:11 PM
Member #5142
let soak with pb blaster spray or wd40 then try an ez out extractor
07-02-2010, 01:52 AM
Member #5711
Bleeder screw
Thanks for your relply. I've had it soaking in penatrating fluid now for 36 hrs--no luck. Maybe I sould take it to a machinist and have him/her a go at it? Or could I turn it right side up--fill the caliber with DOT3 then carefully purge all the air out of the line then re-attach the line to the caliber. Of course I would have to preform this operation with the caliber hanging off the router and perhaps jam a block between the brake pads to do this method.
07-02-2010, 12:09 PM
Member #5717
the literally exact same thing happened to me.. and the ez out broke off inside them... idk why the seize in there like they do. i might try to have mine redrilled. or just got with no brakes. im not sure which yet haha
07-02-2010, 02:01 PM
Member #5711
Bleeder screw
I'm not driving fast and I have back brakes--I might even try just applying a clamp to the front brake on the bad side.
07-02-2010, 02:06 PM
Member #5717
you could do that. but if i understand what your doing correctly, its goin to make that wheel not wanna turn. and you might not be able to get the tire on because the clamp could be in the way. but that is something you would just have to take the tire off and look at.
07-03-2010, 03:14 AM
Member #5711
bleeder screw
What I meant was just put alamp on the brake hose going to that wheel.. It is done often on cars when a break line hose has failed as a temporary fix.
07-03-2010, 03:16 AM
Member #5711
Sorry-I meant clamp--spelling mistake.
07-03-2010, 06:39 PM
Member #5717
oh ok. then that should be just fine lol.
95 polaris bleeders broken, 95 polaris magnum 425 brakes, atv brake bleeder broke off, atv brake bleeder screw repair, atv brake caliper bleeder valve repair kit, bleed screw polaris, brake bleed screw broke, brake bleeder screw sizes, broke the bleeder vavle on brake caliper on polaris scrambler, broken back bleeder on a 91 polaris trailboss what do i do, broken bleeder valve on atv, polaris bleeder replacement kit, polaris bleeder screw, polaris brake bleeder broke, polaris brake bleeder busted off, polaris brake bleeder screw, polaris brake bleeder valve, polaris brake bleeding screw, polaris trail boss blee der screw boken, repairing polaris bleeder screw
