2001 magnum 325 4x4 Master cylinder ? - Polaris ATV Forum
post #1 of 6 (permalink) Old 07-05-2010, 05:44 PM Thread Starter
axulsuv's Avatar
Question 2001 magnum 325 4x4 Master cylinder ?
Hey Folks ; 01 magnum 325 4x4 ... Is there another Handle bar mounted master cylinder that will bolt on , and have the option of being rebuilt ?
The one currently on the quad has been bled , mity vaced , Motion pro reverse bled and still will only develop enough pressure to work the light switch , But not enough to even polish the rust off the rotors ... Road the beastie this evening and it runs fine now , foot brake slows ya' down , but need the front cylinder to work before I deliver the bike to a 70yr old hunter ... I know there is a polaris out there that can point me in the right direction !!!
axulsuv is offline
post #2 of 6 (permalink) Old 07-05-2010, 09:20 PM
Bruce! is offline
post #3 of 6 (permalink) Old 07-05-2010, 11:40 PM
you can use a master cylinder on your machine if you find a donor one off of any of the following machines. hope this helps you:
2001 WORKER 500
2001 XPEDITION 325
2001 INT'L BIG BOSS 6X6
2001 SPORTSMAN 500 HO
2001 SPORTSMAN 500 DUSE HO
2001 XPEDITION 425
2001 SPORTSMAN 6X6
2001 MAGNUM 325 2X4
2001 325 MAGNUM 2X4 HDS
2001 MAGNUM 325 4X4
2001 MAGNUM 325 4X4 MOSE
2001 MAGNUM 500
2001 500 MAGNUM 500 HDS
2001 XPLORER 400
2001 SPORTSMAN 400
2001 DIESEL
2001 325 MAGNUM 4X4 HDS
2001 SPORTSMAN 400
2001 SPORTSMAN 500 RSE HO
2002 ATV PRO 500 4X4 PPS
2002 LUH 6X6 PPS
2002 MAGNUM 325 2X4
2002 MAGNUM 325 2X4
2002 325 MAGNUM 2X4 HDS
2002 MAGNUM 500 2X4 HDS
2002 MAGNUM 500
2002 XPLORER 4X4
2002 XPEDITION 425
2002 SPORTSMAN 6X6
2002 INT'L BIG BOSS 6X6
2002 TRAIL BOSS
2002 MAGNUM 325 4X4
2002 MAGNUM 325 4X4
2002 MAGNUM 325 4X4 FREEDOM
2002 325 MAGNUM 4X4 HDS
2002 MAGNUM 500 RMK
2002 500 MAGNUM VL HDS
2002 XPLORER 400
2002 SPORTSMAN 400
2002 SPORTSMAN 500 ALL OPTIONS
2002 SPORTSMAN 700
2002 XPEDITION 325
2003 SCRAMBLER 500 4X4
2003 MAGNUM 330 2X4
2003 MAGNUM 330 4X4
2003 500 MAGNUM 4X4 HDS
2003 SPORTSMAN 500 HO
2003 SPORTSMAN 600
2003 SPORTSMAN 6X6
2003 TRAIL BLAZER 250
2003 TRAIL BLAZER 400
2003 TRAIL BOSS 330
2003 SPORTSMAN 400
2003 SPORTSMAN 700
2004 A04BA25CA TRAIL BLAZER
2004 A04CA32AA TRAIL BOSS 330
2004 MAGNUM 330 4X4
2004 A04BG50AA SCRAMBLER 500 4X4
2004 MAGNUM 330 2X4
2004 A04CH42AQ SPORTSMAN 400
2004 A04CH50AQ SPORTSMAN 500
2004 A04CH68AK SPORTSMAN 700
2004 A04CH68AU/CU SPORTSMAN 700
2004 A04CH42AA SPORTSMAN 400
2004 A04CH50AA SPORTSMAN 500
2004 A04CH59AF SPORTSMAN 600
2004 A04JD50AA ATP 500 4X4
2004 SPORTSMAN 700 MILITARY
2004 SPORTSMAN 6X6
2004 ATP 330 4X4
2004 A04CH68AC SPORTSMAN 700
2004 A04CH59AK SPORTSMAN 600
2004 MAGNUM 330 4X4
2004 SPORTSMAN 6X6
2004 ATP 330 4X4
2005 TRAIL BLAZER
2005 SCRAMBLER 500 4X4
2005 MAGNUM 330 2X4
2005 SPORTSMAN 6X6
2005 SPORTSMAN 6X6 MV
2005 SPORTSMAN 700 EFI
2005 SPORTSMAN 700
2005 TRAIL BOSS 330
2005 MAGNUM 330 4X4
2005 SPORTSMAN 400
2005 SPORTSMAN 500 HO/INT'L
2005 SPORTSMAN 600
2005 SPORTSMAN 800 EFI
2006 TRAIL BLAZER
2006 SCRAMBLER 500 4X4
2006 TRAIL BOSS 330
2006 SPORTSMAN 500 HO
2006 SPORTSMAN 700
2006 SPORTSMAN 700 EFI
2006 SPORTSMAN 800 EFI
2006 MAGNUM 330 4X4
2006 SPORTSMAN 6X6
2006 SPORTSMAN 450
2006 SPORTSMAN 500 EFI
2007 SPORTSMAN 6X6
2007 SPORTSMAN 6X6 MV
2007 SCRAMBLER 500 2X4 INTL
2007 SCRAMBLER 500 4X4
2007 TRAIL BOSS 330
2008 TRAIL BOSS 330
2008 TRAIL BLAZER 330
2008 SCRAMBLER 2X4 INTL
2008 SCRAMBLER 500 4X4
2008 SCRAMBLER 500 4X4 INTL
2008 SPORTSMAN 6X6
2009 TRAIL BLAZER 330
2009 SCRAMBLER 2X4 INTL
2009 SCRAMBLER 500 4X4
2009 TRAIL BOSS 330
2009 SCRAMBLER 500 4X4 INTL
2009 SPORTSMAN 800 EFI 6X6
2010 SPORTSMAN 800 EFI 6X6
2010 TRAIL BOSS 330
2010 TRAIL BLAZER 330
2010 SCRAMBLER 500 4X4
blueline15 is offline
post #4 of 6 (permalink) Old 07-06-2010, 03:02 AM Thread Starter
axulsuv's Avatar
So I take it just about any later model cyl. will fit ?
Thanks,
Glenn
axulsuv is offline
post #5 of 6 (permalink) Old 02-13-2011, 06:06 PM
NHmud's Avatar
Send a message via Yahoo to NHmud
Hey Blueline15 Where did yuo get such a list? It would be great to have a list of interchangable parts to reference like that. Could have used such a list for My radiator.
NHmud is offline
post #6 of 6 (permalink) Old 02-22-2011, 06:06 PM
elmerkit's Avatar
Yes they are interchangeable so problem on installing, welcome.
elmerkit is offline
Replacing an OLD Master Cylinder with a used one. Nondem ATV Brakes & Suspension 3 10-27-2010 12:09 PM
Master Cylinder Bad, is this one rebuildable? PolarisOne ATV Brakes & Suspension 7 04-23-2010 04:17 PM
Master cylinder del ATV Brakes & Suspension 1 04-11-2010 05:09 AM
Master cylinder justincsandbar Polaris Scrambler 2 12-12-2009 07:47 AM
How to replace master cylinder on Magnum 325? cdn_cajun ATV Repair and Maintenance 2 08-03-2009 09:01 PM
