08-31-2010, 10:48 AM
Member #2669
air ride suspension
anybody considered an air ride suspension for their xp? i've considered it for my touring. when my wife and i ride together i adjust my shocks to the stiffest setting to give the most clearance. but if i ride by myself i prefer the front be set to the softest and the rear set to the second softest. i think the xps handle better with the shocks softer. they dart far less when you get into the throttle on gravel or fire roads at higher speeds. plus, obviously they ride better to. any one have any ideas?
Ransom Proctor
2010 Polaris Sportsman 850 Touring with EPS
2009 Polaris Ranger 700XP
2008 Arctic Cat 250
2007 Sportsman 450
2006 Predator 90
08-31-2010, 02:41 PM
Member #2920
I think it would be awesome if you could get some air shocks for this quad. I know Can Am just did that on their Outlander Max Mud Edition for 2011. You would need an onboard compressor to get it to work though.
 - Polaris 3500 Winch
- Viking Hause Fairlead and Safety Thimble
- Elka Stage 1 Triple Rate Shocks with Rebound
- Front Lock n Ride Storage Box
- WES Lock and Ride Rear Touring Box
- Rotopax Front Storage Fuel Cells
- Hand Warmers
- Garmin GPSMap 62S
- 27" Grim Reapers
- 8000K HID Lights
09-01-2010, 09:43 AM
Member #2669
a friend of mine has a 2010 outlander max 800ltd and he has the air ride suspension. i like the ease of adjustablility. when he and his wife ride rocky sections where you need a lot of ground clearance its pretty sweet. then when riding smoother area's or riding 1up you can adjust it softer. i still think the polaris has a better ride than the can am.
how do you like your elka shocks? how easy do they adjust. the main reason i dislike the stock shocks is because you have to take the rear tires off to adjust the rear shocks very easily. the fronts adjust easy.
Ransom Proctor
2008 Arctic Cat 250
2007 Sportsman 450
2006 Predator 90
09-01-2010, 10:25 AM
Member #6922
You could also get a small compressed air cylinder like a 1lb to 2lb nitrous bottle. Check out statelinecustoms.com they have an ranger airbagged on there
09-01-2010, 11:03 AM
Member #2920
I love my Elka shocks. Since I got quad rate shock springs it's still smooth for slow riding, but stiff enough to never bottom out or dive hard under heavy braking. They are very easy to adjust. I can do everything on the front end very easy from the side of the quad. The rear clearance is so tight that the rebound adjuster is a chore to get to with the wheels on but i found the right tool at sears to give me access on the trails.
I found that after I got them tweaked in I haven't had to adjust them again. I'm sure that with my snowplow in the winter that I will have to crank the front preload up a bit, but that's cool. I know my settings all the way around so I can get back to it in tue spring.
- Hand Warmers
- Garmin GPSMap 62S
- 27" Grim Reapers
- 8000K HID Lights
09-09-2010, 09:07 PM
Member #7052
This is probably a stupid question but would air shocks for automotive use possibly be used on the rear of a polaris 300 hawk eye.Just a thought you could install airline on rear of atv and air them up or let the air out when needed.Mounting bracket for shocks looks like a car shock would fit.Anyone got any ideas.
09-10-2010, 02:58 AM
Member #2920
Even though they might fit the valving would be all wrong for an off-road application.
Anything is worth a try if you have the parts on hand
- Hand Warmers
- Garmin GPSMap 62S
- 27" Grim Reapers
- 8000K HID Lights
09-10-2010, 05:09 AM
Member #5965
I know Thor had a Honda Rincon with automobile air shocks on the back. I saw the post on rinconriders.com. Shot him a pm.
2008 Sportsman 800. Stealth black. HIDS and Ricochet Skid Plates.
2009 Sportsman 850XP. HIDS, Wes Lock and Ride box, 3 in 1 ATV hitch and Ricochet Skid Plates from www.TheATVSuperStore.com
09-20-2010, 05:33 AM
Member #5749
oh my garsh!!!! thats the real original quadman!!!!!!!!!! i've got to tell people! i wonder if he is available for my sons Barmitzvah!!!!!!????
09-20-2010, 11:08 AM
Member #5965
What date were you thinking? Would have to check with Misses Quadman to see if we are available! ;-) I AM QUADMAN!!!!!
air ride for polaris ranger, air shocks for atvs, air shocks for polaris, air shocks for polaris ranger, air suspension atv, atv air bag suspension, atv air bags, atv air ride, atv air ride suspension, atv air shocks, atv air suspension, polaris air ride, polaris atv air shocks, polaris ranger air ride, polaris ranger air shocks, polaris ranger air suspension, polaris suspension air, rear air shocks for polaris atv, rear air shocks polaris ranger, suspension air to atv
