Old 09-02-2010, 06:49 AM
RubiconChris's Avatar
Member #5890
Why are my new brakes squeaking
I put new rear pads on my 08 sportsman 500 efi and the dam things wont stop squeaking. Why would they do this? Will they break in? I put on over 60 miles with them already. Do i need to put some kind of noise supressor on the pads?
Old 09-02-2010, 03:49 PM
sportsman 400's Avatar
Member #6729
I put new pads on my 01 and they still squeek even after 400 miles. I've tried cleaning with brake clean and running the rear brake when i'm moving to "break them in". nothing seems to work for me. Haven't tried the no squeek stuff you get on car brakes maybe that will work.
Old 09-02-2010, 06:24 PM
are they OEM pads or aftermarket? the material of the pad alone can make them squeal
Old 09-03-2010, 02:31 PM
Member #6729
mine are aftermarket
Old 09-06-2010, 06:20 AM
Member #5890
Mine are aftermarket also. Does that make a differance?
Old 09-06-2010, 09:36 AM
depending on the quality of the pad, yes. there are different materials the pads can be made from, and the "harder" pads will always give you that "metal on metal" squeal. you aftermarket pads are probably a different material then OEM and are now squealing on the rotors
Old 09-06-2010, 12:55 PM
jshields's Avatar
Member #6457
Yea the same is true for most car brakes also. The price you pay for the longer lasting pads is a harder surface of the pad itself which can cause the noise mentioned. Several other things that you may hear are grinding and scraching. If the noise has not gone away by 60-100 miles of braking, then it probably will not. Sometime after a ride in sand i noticed that my tend to make a little noise and can be taken care of with a little washing. Did you replace the brakes yourself? If not next time you have your wheel off, check the rotors to make sure nothing is wrong with them.
Old 09-06-2010, 01:10 PM
Manaen's Avatar
Member #6699
I would coat the back of the pad (piston side) with some anti squeal compound used on automotive brakes. That should take care of the squeal. As stated full or semi metallic pads will make more noise due to harder pad surface.
Old 09-06-2010, 05:58 PM
chopper89's Avatar
Member #1634
I have replaced pads on mine machines with polaris pads and no noise, mine guess its the aftermarket pads.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 09-07-2010, 06:59 AM
Member #5890
Thats what I get for buying $15. e bay pads. The Polaris dealer wanted $65. I think I made the wrong choice, you get what you pay for. The squeak has got to go. Thanks for the help.
atv back brake squeks
atv brakes squeak
atv brakes squeaking
atv brakes squeal
brakes squeaking on coolster atv
how to srop atv brake squeal
my brakes are squeky on my atv
polaris brakes squeak
polaris sportsman squeaking brkes
polaris squeaky brakes
rzr brake pad squeal
squeaky brakes atv
squeaky breaks fourwheeler
squeling brakes on a 05 polaris sportsman 500
what makes back brakes squeak on a fourwheeler
why are my new brakes squeaking
why are the brakes squeaking on my polaris
why do my brakes squeak on my atv
why do my new brakes squeal
why does my 08 f-350 squeal when taking off
Help Brakes Stevehi ATV Brakes & Suspension 3 11-21-2011 09:04 AM
800 Brakes bomberguy ATV Brakes & Suspension 3 06-27-2010 06:44 AM
04 atp 330 brakes NotQuik ATV Brakes & Suspension 1 05-24-2010 01:50 AM
brakes on 09 xp 550 kohen ATV Brakes & Suspension 2 05-03-2010 05:28 PM
brakes triefff Polaris Scrambler 2 12-18-2009 09:58 PM
