  #11 (permalink)
Old 09-21-2010, 09:58 AM
CinciMudLuvr's Avatar
Member #7420
Please let me know how they perform for you. I've read (in another forum) that the cage has exploded, on the first ride after install, on a bunch of people with those axles. Although, the ones that detonated on peeps were on modified ATV's...
Thanks,
Digger
05 Sportsman 700
2" lift
Clutch kit
3 light mod
28" MudZillas
  #12 (permalink)
Old 09-26-2010, 05:24 PM
warhorse149's Avatar
Member #7628
Thank you;
I'm looking for info on axle spline counts. Specifically on the rear of the sportsman 700,yr 2006
  #13 (permalink)
Old 04-01-2012, 01:58 PM
dieselfreek26's Avatar
Member #24773
What does it mean when you can spin the axle shaft and wiggle it around by the case? My only rear wheel that spins is my right rear... I hope I didn't tear anything major up.
  #14 (permalink)
Old 04-01-2012, 02:08 PM
Member #24773
I just removed the axle and I think the teeth on the cv shaft are all worn down. What do I do from here? Do I buy a whole new shaft and hope the receiving end teeth aren't worn down or what? 2002 SP 700
2000 polaris sportsman 335 forums rear drive axle
2002 polaris sportsman 700
2004sportman4004x4
2010 polaris rear axle remove
a tool for taking off a polaris axle cup
disassemble a rear atv axle
how do you get the rear axles out of polaris 700 atv if all that is there is the axle cups?
how do you take apart rear axle of a polaris 90
how to get seized up axle out rear diff on a polaris
how to remove rear axle from polaris ranger
mudzillas
polaris ranger rear axle removal
polaris ranger rear end disassembly
polaris rear axle removal
polaris sportsman 700 atv axle removal
polaris sportsman 700 rear axle removal
polaris sportsman rear axle removal
removing atv axle
removing polaris rear axle
removing rear wheel bearings polaris ranger 6 x 6
rear drive shaft removal 304ronnie ATV Repair and Maintenance 8 08-26-2011 11:18 AM
2002 Sportsman 700 rear drive shaft removal pbm1957 ATV Repair and Maintenance 5 01-20-2011 08:49 AM
rear 1/2 shaft removal problems sped64 ATV Repair and Maintenance 0 04-10-2010 02:44 PM
HELP 03 Ranger Rear Axle removal Airpig95 ATV Repair and Maintenance 1 10-25-2009 05:01 PM
HELP, rear drive shaft removal. rust Polaris Sportsman 2 08-16-2009 03:58 PM
