Old 09-07-2010, 08:56 AM
Chazzo's Avatar
Member #7062
Left rear axle shaft removal.
Hello, all. I'm new here. This is the first time I've ever been really stumped regarding a repair to my machine.
I have a 2004 Sportman 400 4x4. The left rear axle shaft blew apart into pieces. All thats left is the "bell" portion of the axle where it goes into the transmission. I cannot figure out a way to remove it. Since the renmaining portion of the shaft is no longer attached, I can't give it a "sharp" pull to remove it from the tranny. Any suggestions? I have a brand new axle waiting to be installed and get me back on the trail. Any help would be greatly appreciated. Thanks all.
Old 09-07-2010, 05:44 PM
Member #1958
WOW!! You might try a slide hammer if you can get access to one or maybe weld a bar across the end and put both feet on the trans and pull like heck.
Old 09-07-2010, 06:15 PM
Moose heated grips and thumb
Old 09-08-2010, 05:26 AM
Chazzo's Avatar
Member #7062
Thanks.
I've been thinking that I may just drill a couple holes on each side of the cv "bell", put a bolt through and use a slide hammer or just hook up a chain a give it a tug. It's some pretty hard steel, I'm sure its time to go buy some drill bits.
Old 09-20-2010, 09:03 AM
CinciMudLuvr's Avatar
Member #7420
First off, this is my first post to this site at least.
Chazzo~ Take a straight pry bar and place it between the Cup and the diff, give it a tap with a heavy hammer. Turn the other axle a quarter turn and repeat. It might take a few minutes but the cup will pop right out. It is a good idea to soak it in Penetrating oil for a day before you proceed (if you sink the rear esp in mud/water a lot). I just did my right rear last week. Good luck and if you have any questions, let me know.
Digger
Old 09-20-2010, 10:36 AM
Chazzo's Avatar
Member #7062
Digger, thanks for your reply. I did exactly as you stated, that was my first brainstorm. I let it soak and resoak for a couple days in PB Blaster. It just wouldn't move. What I finally ended up doing was, cutting 4 grooves in the cup with a cut off wheel and die grinder. I then welded a 4 claw puller to a slide hammer. After 3-4 pulls, it came right out.
Old 09-20-2010, 11:46 AM
Member #7420
Hey that works too! Although I will say that the other way you can re use the cup. To install the new axle: hold it straight and tap it in with a rubber mallet. Easy!
Here is why I had to rebuild mine!
Digger
05 Sportsman 700
2" lift
Clutch kit
3 light mod
28" MudZillas
Old 09-21-2010, 08:20 AM
Chazzo's Avatar
Member #7062
The cup wasn't worth reusing. I blew the axle apart, like nothing I've ever seen before. The new axle is in, and the machine is back on the trail.
Old 09-21-2010, 09:28 AM
Member #7420
Chazzo~ Where did you get your axle? If you don't mind me asking, how much did you pay for it? Always looking for spare parts just in case. Are you running a lift or larger tires?
Digger
05 Sportsman 700
2" lift
Clutch kit
3 light mod
28" MudZillas
Old 09-21-2010, 10:42 AM
Chazzo's Avatar
Member #7062
I got this axle from superatv.com, I paid $180 which included shipping for a brand new axle. It wasn't an OE axle($300 at the dealer), but it is definitely better quality. No, I do not have larger tires or a lift. I mostly use it for around the property for various jobs. Only occasionally do I hit the trails.
I've also purchased ATV axles at americancvstore.com, they were a little bit higher this time.
2004 polaris sportsman rear shaft removal
how do you get the rear axles out of polaris 700 atv if all that is there is the axle cups?
how to remove left rear axle from polaris ranger 500
how to remove polaris rear axle
how to remove rear axel shaft on 1998 polaris sportsman 500
how to take apart the rear axle on a polaris hawkeye
installing polaris rear axle
mudzillas
polaris 500 rear axle removal
polaris 700 rear axle removal
polaris ranger rear axle die
polaris rear axle removal
polaris sportsman rear axle removal
rear axel removal on polaris 700
rear end 03 ranger
replacing rear axel shaft polaris ranger xp
seized atv axle rear differentail polaris how to remove it
sportsman 700 cant remove rear axels
sportsman 700 parts
sportsman front rack removal
rear drive shaft removal 304ronnie ATV Repair and Maintenance 8 08-26-2011 12:18 PM
2002 Sportsman 700 rear drive shaft removal pbm1957 ATV Repair and Maintenance 5 01-20-2011 09:49 AM
rear 1/2 shaft removal problems sped64 ATV Repair and Maintenance 0 04-10-2010 03:44 PM
HELP 03 Ranger Rear Axle removal Airpig95 ATV Repair and Maintenance 1 10-25-2009 06:01 PM
HELP, rear drive shaft removal. rust Polaris Sportsman 2 08-16-2009 04:58 PM
