Fuel and water packs - Polaris ATV Forum
ATV Gear and Gadgets All gear and gadget discussions here!
 2Likes
post #1 of 12 (permalink) Old 04-18-2017, 08:40 AM Thread Starter
TDMax's Avatar
Resurrecting and old post:
Originally Posted by Ron958 View Post
I was only looking for a couple extra gallons and this location is perfect on the Touring. Just finished mounting the new packs and it turned out great. The lock and ride option will work if I took off my rack extender, but I wanted to keep it on and used bolts with all the rest of the lock and ride mounting hardware. It's very stable and I have been riding with the packs empty to ensure that heat won't be a problem, so far so good.
Attachment 7833
The mount is a standard Roto-pax mount cut down and redrilled with a 14" steel plate welded to it. If I take of the rack extender, I can still move the mount and run the packs vertically or horizontally and use full lock and ride system.
Attachment 7834
Good clearance at the top and bottom of the tanks.
Attachment 7835
Looks clean on the quad and doesn't stick out too far.
Thanks for all the great info on this site.
I'm looking at taking Ron's idea to the next level and having a nice 1pc stainless bracket fabbed up. Plan would be to carry one gas and probably one water can. Both 1 gallon for the ease of installation. I do think that the 1.75 and 2 gallon cans might fit the Touring models with the passengers seat in place, but would require a bit of a rearward shift.
'15 Sportsman Touring 1000 LE bronze mist
'13 Ranger 900XP Browning
'07 Ranger 700XP camo-sold
'06 Honda Rincon 680 EFI
'04 Sportsman 700 carb-sold
'04 Honda TRX 90 for the little guys
'01 Sportsman 500 HO-sold
TDMax is offline
post #2 of 12 (permalink) Old 04-18-2017, 09:01 AM
darius427's Avatar
I believe my brother has the larger Rotopax on his touring with a similar setup. He goes by MTNBKR. If you search his posts I believe he has pictures and some info on how he did it. It works well, been riding quite a bit and they stay put.
My up north ride
2016 Sportsman 570SP (Titanium Matte Metallic)
My at home ride
2013 Sportsman 800 (Green)
Wifes
2015 Sportsman 570SP (Sunset Red)
2013 Sportsman 500 (White)SOLD
darius427 is offline
post #3 of 12 (permalink) Old 04-18-2017, 09:50 AM
jhalpinjr's Avatar
No way I would mount them above the exhaust like that!
2016 Sportsman Touring 850SP
Ricochet Full Armor- Anodized Red
Rick Cecco Frame Bracers
Gorilla Whips - Silverback LED Whip
ATV-Guru Rear Bumper
RAM Mount- Use Polaris RideCommand App
jhalpinjr is offline
post #4 of 12 (permalink) Old 04-19-2017, 05:43 AM Thread Starter
TDMax's Avatar
Username search comes up empty for that name.
TDMax is offline
post #5 of 12 (permalink) Old 04-19-2017, 06:06 AM
darius427's Avatar
Sorry, missed a letter...MNTNBKR
My up north ride
My at home ride
Wifes
post #6 of 12 (permalink) Old 04-19-2017, 06:08 AM Thread Starter
TDMax's Avatar
OK got it. I found his post, but no image. His setup sounds a lot like my design. I sent him a PM.
TDMax is offline
post #7 of 12 (permalink) Old 04-19-2017, 06:13 AM
CSW652's Avatar
Interesting idea for the Touring. Does anyone know the part number and for that mount?
CSW652 is offline
post #8 of 12 (permalink) Old 04-19-2017, 07:05 AM
mvn
mvn's Avatar
I fabricated a couple of brackets and mounted the Rotopax mounting plate to them. I then used the double Rotopax clamps and have a large fuel pack as well as a large storage pack. The small green Plano ammo box fits the lower deck notch area perfectly and is used for tools.
Mark
ID:	77337   Click image for larger version
jhalpinjr likes this.
2012 850HO Touring EPS Pearl White
27" ITP XTR radials on 14" ITP SS212 wheels
Ricochet skid plates & A-arm guards
Rubberdown 1 1/2" lift
Cecco frame braces
JC Capri bushings
Rotopax fuel packs on custom mounts
Garmin 60CSx with Ram mount
Polaris 2500# winch with synthetic rope
Polaris front & rear brush guards
Polaris bar & thumb heaters
Polaris passenger grip heaters
NGK (6043) ILZKAR7A10 plugs
Good, fast, cheap.....pick 2!
mvn is offline
post #9 of 12 (permalink) Old 04-19-2017, 07:14 AM
jhalpinjr's Avatar
This I like. Up away from the exhaust. Any chance you could take some pics of your bracket set up?
Did you drill and mount?
Is the ammo box metal or plastic?
post #10 of 12 (permalink) Old 04-19-2017, 08:33 AM
mvn
mvn's Avatar
In order to make the mount truly robust, had to add plates to the tubular metal subframe under the composite deck. I then chose open spots in the composite deck and bolted the aluminum brackets to the plates underneath (second photo). I first tried Kolpin expansion anchors (first photo) (similar to the Polaris Lock & ride toggles) but they didn't have enough holding power due to the cantilevered load of the Rotopax containers. I also added a support to the rear bumper to take some of the cantilevered load (third photo). In hindsight, the bumper brackets may allow use of the expansion anchors only eliminating the need for the additional plates in the subframe.
The ammo box (I think they call it a field box) is plastic and waterproof.
Mark
Name:	20121107_210508 - Copy.jpg
ID:	77353   Click image for larger version
ID:	77361   Click image for larger version
Cecco frame braces
JC Capri bushings
mvn is offline
Go Back   Polaris ATV Forum > Polaris ATV Discussions > ATV Gear and Gadgets
Common Carb Issues pfunk76 ATV Repair and Maintenance 113 01-06-2017 08:47 PM
Fuel problem aaronlisa.strickland Polaris Magnum 6 09-29-2016 12:14 PM
93 octane? vics570 Polaris Sportsman 570 67 07-04-2016 06:26 PM
Getting ready for the first ride in water... advice appreciated fitsector ATV General Discussion 13 06-21-2016 04:20 PM
RJWC Dobeck 3.5 fuel programmer short bmerwin ATV Performance Modifications 5 04-26-2016 03:23 PM
