Old 12-25-2010, 01:39 PM
chillmouser's Avatar
Member #10425
Smile How to change coolant on a 02 sportsman 400
hi,
I purchased a 02 sportsman 400 a couple days ago with very little use by the previous owner, the first ride i had with my son the temp light came on and it boiled over. So after investigating the problem i found that the temp sensor which was in the bottom of the radiator the wire was burned off. so I bought a new one and today i had put it on, so my question is? since the antifreeze was drained and new put back in, how do i get the air out of the hoses and system or will it work out by itself, im new to liquid cooled atv's. I afraid that i will kill the head gasket.....
thank you
any replies will be greatly appricated!!!!!!!
Old 12-25-2010, 07:13 PM
Welcome aboard!
Old 12-26-2010, 07:03 AM
4getful2's Avatar
Member #1234
There is a lil air bleed bolt down by the water pump housing that you can remove while filling your cooling system, but that doesn't always completely get all the air out. Some people put the front wheels up on 12' blocks to help get the air while running at a fast idle also, it helps. I fill the cooling system put the cap on ,fill the resevoir ,let it run until the fan cycles or if temp. light comes on, shut it off ,wait a few minutes ,when the engine starts to cool it will start sucking the resevoir dry, refill the resevoir and radiator, start and run ,again, then you should good to go as far as being full. let the fan cycle a couple more times while watching the resevoir and coolant light. The cooling system only holds two quarts
Old 12-26-2010, 09:11 AM
Member #10425
Thank for the info, I will try that
thanks!!!!
add coolant polaris 400 atv
change coolant atv sportman
flushing coolant system polaris 400 sportsman
how do i bleed the cooling system in a 03 polaris sportsman 400
how do i change coolant in a 1995 polaris sportsman 400
how do you change the antifreeze in a polaris 1994 sportsman 400
how to change antifreeze 2002 polaris sportsman 500
how to change antifreeze on a polairs sportsman 400
how to change coolant polaris sportsman
how to fill antifreeze polaris sportsman 400
polaris sportsman 400 coolant
putting coolant in a polaris 400 sportsman
refilling coolant in polaris ranger utv 4x4
sporstsman 400 air in coolant
where to put coolant in a polaris 400 sportsman
Allied Electricals: Coolant Pump | Industrial coolant Pump in India Bangalore Allied Site Issues & Suggestions 1 11-19-2010 01:13 PM
04 sportsman 600 loosing coolant! PLS HELP! 600 sportsman ATV Repair and Maintenance 1 10-25-2010 04:06 PM
Coolant Change Info 2000 Scrambler 500 4x4 Kiefer34 ATV General Discussion 2 09-23-2010 07:20 PM
04 Sportsman 700 Leaking Coolant Sekora ATV Repair and Maintenance 4 06-04-2010 06:02 PM
2000 sportsman 500 leaking coolant kaboomb ATV Repair and Maintenance 2 09-23-2009 03:14 PM
