Help with handlebar warmer wiring please - Polaris ATV Forum
post #1 of 9 (permalink) Old 01-06-2017, 10:31 PM Thread Starter
liquidmonkey's Avatar
Just put on some new handlebar warmers from cycle country and I'm stuck at the wiring part. There is an included on/off/low/high push button toggle switch. NO thumb warmer.
Instructions state 'connect the blue wire to the negative battery terminal' which would go to the black wire on the battery. The other wire on the battery is red.
Right so far?
The only other wire is grey and should be 'connect grey (positive) to a switched power source'.
This grey wire is right next to the blue one and not at all very long.
My questions:
1) how do they expect me to connect such a short wire to a switched power source?
2) what is a switched power source?
3) can I connect it directly to the battery?
So far I've routed all cables into the pod then the two power wires down to beside the battery BUT NOTHING IS CONNECTED YET.
Thanks for any help.
liquidmonkey is offline
post #2 of 9 (permalink) Old 01-06-2017, 11:27 PM
phil's Avatar
Connecting to the battery would not be the best idea. There should be a "free" orange and white wire (maybe 2 of them) with spade ends lying in the front. They are both switched power; meaning they have power only when the ignition switch is on.
3500 lb. Polaris HD Winch
VIPair Windshield
EPI HD Springs, Front & Rear
Cecco Frame Braces
Guru Bumpers, Front & Rear
Rhino Monster, Rear Box
Lowrance BAJA 540 GPS
SuperATV EZSteer 380
Various Mods for Ice-Fishing
phil is offline
post #3 of 9 (permalink) Old 01-07-2017, 05:58 AM
MNTNBKR's Avatar
Phil is correct.
If you connect the switched power wire directly to the battery, it will allow the grip warmers to be turned on (or left on) even when the quad is off, and would undoubtedly lead to a dead battery at the most inopportune time if you were to forget to turn the heated grips off when you turn the quad off. Having the switched power lead connected to a switched power source allows the grip warmers to be shut off automatically when you turn the quad off ensuring that they will not drain the battery.
Also, as Phil stated, there are typically a couple of orange or orange/black switched power leads with spade or bullet connectors available near the front of the quad under the plastics somewhere. If you tell us the year and model of quad that you have, someone will be able to tell you the exact location where you can find them.
2016 Can-Am Outlander Max XT 650, Brushed Aluminum
2015 Sportsman Touring XP 1000 Bronze Mist, Uni-Filter, 2" lift, 28" Bearclaw HTR's, Cobra HD front axles, Glacier Pro Plow system
2008 Can-Am Outlander Max XT 400, Red
1987 Manitou 24' Pontoon w/ 25HP Merc, bimini top, & propane grill
2014 Aluma 8112 utility trailer (my 'lil toy hauler)
1990 Honda Fourtrax 300, blue, plow machine (Sold)
1986 Yamaha Moto 4 225 (sold)
MNTNBKR is offline
post #4 of 9 (permalink) Old 01-07-2017, 10:22 AM Thread Starter
Thanks for the replies and makes perfect sense with the battery.
I have a 2015 sportsman touring 570.
There is a 12v cigarette lighter socket on the pod, maybe that would work?
Or what do you experts say?
post #5 of 9 (permalink) Old 01-07-2017, 10:39 AM
Liftedpsd's Avatar
I connected mine to the cigarette power wire.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Liftedpsd is offline
post #6 of 9 (permalink) Old 01-08-2017, 12:37 PM Thread Starter
Sounds good.
How will I know which is the power wire/connection?
Will look tomorrow after work.
post #7 of 9 (permalink) Old 01-08-2017, 02:26 PM
MNTNBKR's Avatar
Sounds good.
Your best bet is to tap into the already available switch accessory power wires that have the blade or bullet connectors on them. I'm not sure exactly where they are on your model, but it would be worth your time to find out.
Taping into the cig lighter power wire is an OK solution, but there are a couple problems with it. 1) It will require that you either use a tap-in style connector, which are notorious in the 12V community (see here), especially where water and vibration are a regular occurrence, or you can solder a wire in place which will likely take you more time than finding the switched power wires that are already there. 2) If you tap into the cig lighter power, then the power relay for your grip warmers will be sharing the same fuse as the cig lighter. This isn't ideal because if you have a wiring fault in either circuit, both circuits will fail. If you connect to the already existing accessory wire, the hand warmers will be on their own accessory fuse. 3) Polaris put the wires there specifically for this type of application, so you might as well use them.
I did a little looking, and it seems that the wires are probably orange and white as opposed to orange and black as I wrote previously. Also, they're probably located under the removable (four screws) center panel in the front storage compartment. See here. The yellow circled wire / connector is what you're looking for.
If you're set on using the cig lighter for power, that's fine. You'll need to either remove the connector from the back of the cig lighter and check for 12V with a DMM or use a needle type voltage detector to find the "hot" wire.
g'luck
MNTNBKR is offline
post #8 of 9 (permalink) Old 01-10-2017, 03:48 AM
autosport7's Avatar
I tapped into my cig lighter for both the grip warmers and the thumb warmer. The grip warmer connector had a piggyback which made it easy to plug the thumb warmer right in. Once I was done making my connections, although with clips, I still black taped everything to ensure my connections stay tight. I then bought black tubing and put all of my wires in the tube so none of them were directly rubbing anywhere.
2015 Polaris Scrambler XP1000
Red Bull Graphics Kit
Pure Polaris Hand Warmers
Pure Polaris Thumb Warmer
GBC Grim Reaper - 27/9/14 - 27/11/14
Race Driven Brake Pads FR/RR - PURE JUNK
All Balls Wheel Bearings FR/RR
ROX Speed FX Foot Pegs
CECCO Frame Braces FR/RR
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Fasst Flexx Handlebars
ROX 2" Risers
Powermadd Sentenial Handguards
Renthal G169 Grips
autosport7 is offline
post #9 of 9 (permalink) Old 01-10-2017, 09:27 AM
thumper1500's Avatar
On my 2015 Touring, it looks like this
2015 Sportsman XP 1000 Touring
Bronze Mist
QSC Clutch Kit
Ricochet Ultimate Armor Kit
HighLifter 2" lift kit
Kenda Bearclaw HTR 28" tires
Cecco frame braces
Cecco billet front pinion cover
2" hitch w/bottle opener
Mid smoke windshield
Tatou 4s tracks for the snow
Garmin Oregon GPS
Synth winch line and Hawse fairlead
LED headlights
Wired for electric helmets
thumper1500 is offline
92 Polaris 350l 4x4 wiring question tulips26 Polaris Trail Boss 0 11-28-2016 09:49 AM
AWD switch wiring question davis911s Polaris Sportsman 0 07-23-2016 05:29 PM
2002 Sportsman 500 HO Wiring Harness Swap Ekxjar ATV Repair and Maintenance 8 05-24-2016 06:36 AM
