Hand Grip Removal - Polaris ATV Forum
Old 03-14-2011, 03:58 PM
mek83's Avatar
Member #12783
Hand Grip Removal
Hey,
Just got new hand grips for my 06 Hawkeye 300, any tips on easy removal of the stock grips?
Thanks alot
Mek
2006 Polaris Hawkeye 300
2005 Harley Davidson Sportster 1200
2003 Yamaha Wave Runner FX1000
Old 03-14-2011, 04:22 PM
if you have an air compressor and a blow gun , blow in the small hole in the end of one grip, will push the other side off, if no hole, make one, after you get one side uise a rag , wrap around blow gun to fill the space in handle bar, blow the other side off
Old 03-14-2011, 04:27 PM
as said, compressed air does the trick
Old 03-14-2011, 05:31 PM
jstoppok's Avatar
Member #6220
Yep. You can put the new ones on the same way. I just had my wife hold her hand against the open side. Then I stuck the new grip on a little and blew compressed air in the new grip hole. Blew up like a balloon and slid right on. I didn't believe it was that easy until I tried it.
2010 Polaris X2 550
ATV-Guru Cobra bumpers, Polaris front and rear A-Arm protectors, heated hand and thumb grips, 3500lb winch, hand guards, gun scabbard, 3" passenger foot risers, Glacier III plow, HID Lights, Tiger Tail, 9" Windshield
Old 03-14-2011, 07:23 PM
cwlongshot's Avatar
I have seen the compressed air trick and it does work... I cheated, 2 sec with a razor and mine peeled right off...
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
Old 03-15-2011, 03:06 PM
mek83's Avatar
Member #12783
Worked great, thanks guys!
Mek
Old 03-16-2011, 11:33 AM
bakada's Avatar
Member #2821
I worked 10 years at a bicycle shop through out high school and college. We were constantly taking grips on and off. Most of the time we used the air compressor trick but some times we came across some that were stuck and that didn't want to blow off. If you don't have an air compressor or you cant get them to blow off. Stick a small screw driver in between the bar and the grip and spray some window cleaner or some soap product down the gap made by screw driver. We would use a product called Schwinn bike polish but it was just a foaming soap product that wiped off easily. If we encountered a set that was really tough or else had been glued on we would squirt WD40 down the slot made with the screw driver. This would dissolve anything holding the grips on and you could slip them off. If you use WD40 or any other penetrating lubricant you need to clean the bars and old grips good or else the grips (either old or new) might not grip and will slip on the bars. We would install grips with the bike polish(soap product).Just spray a bunch into each grip. Slip them on and after a few minutes it would dry leaving the grips stuck to the bars. I recently installed hand warmers on both my 700 and 500. The grips blew right off and a little bit of foaming bike polish and they slipped back on over the heating elements and dried nicely.
04 Sportsman 700 efi black and silver, Big Gun Evo exhaust and tuner,3 light mod,reverse override,bar and thumb warmers,Moose pregressors,Black Rock wheels,Polaris(warn) winch and plow, 2 inch receiver, Filtermag.
00 Magnum 325 not very HO green, rolled, wrecked and rebuilt,heated grips and thumb warmer, Filtermag.
atv grip removal
best way to remove atv hand grips
how to remove atv grips
how to remove atv hand grips
how to remove atv handlebar grips
how to remove grips from handlebars
how to remove hand grips on a 2015 polaris sportsman570sp
how to remove heated grips on an atv
remove handlebar grips from polaris x2
remove heated handle grips polaris sportsman 500
removing atv grips
removing grips on an atv
Thumb Throttle VS Twist Grip Throttle Billster1955 Around The Garage 14 04-02-2013 01:11 PM
SPI heated grip parts willysrule ATV Repair and Maintenance 3 02-26-2011 08:11 AM
2004 Sportsman 90 Grip warmers freerida702 ATV Performance Modifications 2 01-09-2011 07:30 AM
2004 Sportsman 90 Grip warmers and headlights??? freerida702 ATV Performance Modifications 1 01-09-2011 06:44 AM
Duro Power Grip bf750 ATV Wheels & Tires 4 09-02-2009 10:19 PM
