unit will not rev out - Polaris ATV Forum
Old 05-09-2011, 07:32 AM
muddybuddy's Avatar
Member #14874
Hello fellow mudders
I have a slight problem with my 2004 sportsman 700.It fell off the trailer going up the hi-way and it will not rev out.It starts and runs but will not rev past 2500rpm.It does have throttle control housing damage.
Does a Polaris have a electronic mechanism in that housing that will put unit to a limp mode if damaged? i see there is 5 wires plugged in to the housing for just 4wd on and off.
Old 05-09-2011, 05:35 PM
it does have etc-electronic throttle control, in the box above the thumb throttle is a set of points if theres too much slack in cable it will cut the power, kinda misses and bacfires, theres an adjutment about 4 inches from thumb throttle in the cable
Old 05-09-2011, 06:32 PM
Old 05-10-2011, 12:03 PM
muddybuddy's Avatar
Member #14874
Thanks Russ C.I am replacing the complete throttle housing.Will try then.Its just that after you drive 5 hrs to get to your atv destination and it falls off the trailer upside down we rushed to try to get it to be ridable.
Hello Bruce i am glad i have joined the Polaris Team
Old 05-10-2011, 02:53 PM
M_Quick's Avatar
Member #13816
After you get that fixed pick up some of these, worth the $12.99 investment to preserve the life of your quad.
4 Piece 1" x 15 Ft. Ratcheting Tie Down Set
2001 Polaris Scrambler 500 4x4 Stolen @ MJ USA
(2) 2003 Polaris Sportsman 90cc
2006 Polaris Predator 50
2006 Polaris Phoenix 200
2008 Honda Trx700xx
Old 05-10-2011, 06:23 PM
Bigdog800EFI's Avatar
Member #14008
400 lbs working load on the straps you have in the link...... I would not trust those to strap down a little tyke atv
Old 05-12-2011, 01:20 PM
M_Quick's Avatar
Member #13816
Yea well just keep loading it your way, seams you have all the answers. I'd think 4 straps rated at 400lbs each would keep a quad on a trailer. And I always just use a bungee cords for my little tikes, and gas cans. Havnt lost one yet.
2008 Honda Trx700xx
Old 06-07-2011, 12:51 PM
muddybuddy's Avatar
Member #14874
Reverse Limiter Condition in Forward
Right now straps least of my worries but thanks for the advice gentleman.My situation has not changed and i have gone through Polaris manual to correct this situation.
I have eliminated through testing procedures the cable adjustment,cdi,speedo gauge,reverse limiter.
Kinda funny though it says to test reverse limiter systen then at end of test it has a small box saying that the override switch has nothing to do with reverse gear output so the test for check reverse limit is null ???
Has anyone had this happen to them it like the same condition as the reverse limiter is on in forward ?
Thank Polaris Brothers
2004 polaris sportsman 700 limp mode
2006 polaris predator 90 doesnt rev
2006 polaris sportsman 90 will not rev
polaris phoenix wont rev
polaris ranger 500 wont rev up
polaris ranger rzr 170 wont rev up
polaris rzr 170 wont rev up
polaris rzr wont rev up
polaris rzr800s limp mode
razor 170 limp mode
rzr 4 limp mode
rzr 800 limp mode
