Can I ride on a bad cv joint? - Polaris ATV Forum
post #1 of 13 (permalink) Old 05-11-2011, 07:12 AM Thread Starter
secondsole's Avatar
The boot is torn on the rear left, and clicking. I'm assuming it's the joint, or the axle...either way, can I still ride on it, or will it leave me stranded? It's a 2009 850xp. thanks.
secondsole is offline
post #2 of 13 (permalink) Old 05-11-2011, 07:27 AM
JSmith's Avatar
If it breaks when u are on the trails u will still have the other rear tire pulling. If its bad, its bad. I would let her got until it gets to making a little more noise than a click. IMO.
2011 CAMO 850XP
RACK EXTENDER
FRONT BRUSH GUARD
POLARIS 3500 SYNTHETIC WINCH
JSmith is offline
post #3 of 13 (permalink) Old 05-11-2011, 07:46 AM
Daveboys's Avatar
I had a tore boot on mine and it was clicking, I repacked the joint and replaced the boot 4 years ago. It still clicks but hasn't failed yet.
Daveboys is offline
post #4 of 13 (permalink) Old 05-11-2011, 11:57 AM
SNW629's Avatar
at least replace the boot,the cv joint will not last long with a torn boot,if you want the clicking gone replace the cv joint at the same time.clicking cv joint is a common polaris complaint.
2010 850XP EPS,ITP XTR,DALTON CLUTCH KIT,WARN RT30,KFI MOUNT.HMF SWAMP XL.
SNW629 is offline
post #5 of 13 (permalink) Old 05-11-2011, 12:58 PM
Esh
Esh's Avatar
To properly replace a boot (not using a split boot that's notorious for leaking) you need to dissasemble the joint. Might as well replace the joint while you're in that far.
The joint clicks because the ball cage is cracked. If the cage completely splits, it can spit the balls out of the race and you will loose the joint. Could happen now or years from now but sooner is more likely since the joint is running dry.
Esh is offline
post #6 of 13 (permalink) Old 05-11-2011, 01:48 PM
flintstriker's Avatar
Do it right and replace the joint and boot.
flintstriker is offline
post #7 of 13 (permalink) Old 05-11-2011, 01:50 PM
Daveboys's Avatar
Mine was not cracked. When I had it disassembled I cleaned it and inspected it. I thought it would be ok, but now it clicks when backing up.
Daveboys is offline
post #8 of 13 (permalink) Old 05-11-2011, 04:00 PM
cwlongshot's Avatar
Exclamation
Originally Posted by SNW629 View Post
at least replace the boot,the cv joint will not last long with a torn boot,if you want the clicking gone replace the cv joint at the same time.clicking cv joint is a common Polaris complaint.
EXACTLY!!!
It's likely clicking form the loss of grease, if not tended to in a timely manor, it will wear and the clicking will remain regardless of grease.
You cane get "repair" boots that snap around the shaft while still in place. They are temporary or a "band-aid" but will keep you riding until you can correctly repair the shaft.
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
cwlongshot is offline
post #9 of 13 (permalink) Old 05-11-2011, 04:24 PM
Esh
Esh's Avatar
Ok, should add a "Generally," to the beginning of my last post. It can also be caused by worn or missized balls/hub. I'd say 8.5/10 of the bad CV's I've pulled apart had a hairline split somewhere in the cage.
Is your's constantly clicking while backing up, or just one or two clunks? Might have some lash between the hubs and balls if it's clunking when first giving it gas.
I've found even new CV joints what I consider "worn" or mismatched from the factory and rebuilders. Should be able to pivot the joint in all direction freely with no binding or feeling of galling, but while holding the stub in one hand and the shaft in the other and trying to rotate against each other there should be no play at all.
My .02
Esh is offline
post #10 of 13 (permalink) Old 05-11-2011, 05:14 PM Thread Starter
secondsole's Avatar
Thanks for the replies - the verdict is we got STRANDED! The axle broke away from the joint about 2hrs in and we had to tow it back. My Polaris is 'adult ridden' and I ride gently. VERY disappointing with only 200miles on it, very...lesson learned.
U joint rifleman24 ATV Repair and Maintenance 1 11-06-2010 05:55 AM
U joint rifleman24 Polaris Sportsman 4 11-05-2010 05:31 AM
is it my cv joint? z_meeks93 Polaris Sportsman 3 11-02-2010 09:12 PM
Rear tire ball joint CV joint? rich in co Polaris Sportsman 3 08-22-2010 01:55 PM
Need Cv Joint help ibucarl ATV New Members 1 09-22-2009 03:29 PM
