2004 Polaris sportsman 400 wiring problem - Polaris ATV Forum
post #1 of 7 (permalink) Old 07-02-2011, 12:23 PM Thread Starter
Daleas88's Avatar
My brother and his friend Hooked a battery up backwards and fried something, no burnt wires visible but now when u connect a battery the fan kicks in with key off and if you put the key on it does nothing at all. That being said, if you disconnect the cdi box?(not sure if that's the part, it's a metal piece with slots in it) if u disconnect that and hook up a battery it does not kick the fan on but nothing happens with display... Any ideas?
Daleas88 is offline
post #2 of 7 (permalink) Old 07-02-2011, 07:06 PM
Bruce! is offline
post #3 of 7 (permalink) Old 07-03-2011, 09:03 AM
MUDDIE49's Avatar
Check all your fuses and breakers...you might have shortered the pmd module...thats what i'm quessing....Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System. 2010 camo
SunPro Temp gauge. 550xp Sportsman
Xbow Gripper mount
~DOWN&DIRTY~
MUDDIE49 is offline
post #4 of 7 (permalink) Old 07-05-2011, 05:31 AM
stefanj's Avatar
The box your talking about is actually the voltage regultor. Good news is that its probably ok (at over $200 your lucky), Bad news is that you have to run ALL the wires and check the inline fuses (most are sealed in these rubber bags and are a pain to get at. Your gonna have to look at the fan control module. THe fans normal position is on- and the control module (I'm sure there is a more technical name for it) keeps the fan off until the temp sensor turns it on. Be sure to check all your ground wires also as these can melt pretty easily. Not 100% positive but the battery might be toast also (if you didn't already change it out)
03 Magnum 330 4x4 Mossy Oak
Cycle Country 48" plow
Superwinch LT2000
GuideGear rear drop rack basket
Koplin seat cover
Front and rear rack bags
rear tire chains
rear work light (walmart)
8 acres of personal riding space
stefanj is offline
post #5 of 7 (permalink) Old 01-15-2012, 05:44 AM
donkey's Avatar
my old man just did that hooked up the battery wrong heard a pop,
$200 later it was the ecm that was shot, the rad fan was the only thing that came on with or without the key on. ill bet 100% its your ecm
hope this helped
donkey is offline
post #6 of 7 (permalink) Old 01-15-2012, 06:33 AM
yep, bad ecm is my guess too
Russ C is offline
post #7 of 7 (permalink) Old 01-17-2012, 04:36 PM
woodycb's Avatar
hope this helped
I did the same thing. The ecm module was fried. Got lucky and found one on ebay for $100
woodycb is offline
wiring diagram for Polaris Sportsman Mik777 ATV Repair and Maintenance 8 11-23-2013 09:33 AM
2004 polaris Sportsman 500 HO Electrical problem millerman Polaris Sportsman 3 12-28-2010 08:50 PM
sportsman 600 wiring problem astrozombie ATV Repair and Maintenance 0 07-30-2010 07:49 AM
wiring problem with 04 sportsman 600 astrozombie ATV New Members 2 07-30-2010 05:04 AM
2004 Polaris Sportsman 400 4X4 Guage/4X4 Problem joeschmoes ATV Repair and Maintenance 3 11-24-2009 04:34 AM
