Continuing on with the specifications and features of the 2012 Polaris ATV line up from this thread:
2012 Polaris ATV Line Up
SPORTSMAN BIG BOSS 6x6 800 EFI
NEW! IntegratedFront Storage with 6.5 gal/24.6 liter capacity, a 21% increase in volume vs. Model Year 2011 front box
760cc, twin EFI engine
55 HP
Aggressive design with enhanced sight lines
Polaris On Demand True Six-Wheel Drive
Engine Braking with Active Descent Control
Hydraulic Disc Brakes on all six wheels
1500 lb/680.4 kg towing
800 lb/362.8 kg rear dump box capacity, 100 lb/45.4 front rack capacity
Low winch mount
Sportsman XP-styled bumper headlights
Improved radiator location- raised up more than 3-inches/7.6 cm and angled forward for better mud protection
Analog/digital gauge
Kenda K590 tires
Six-wheel shaft drive with six-wheel independent suspension with 6.12 in/15.5 cm travel
MacPherson strut front suspension with 8.2 in/20.8 cm travel
10.5 in/26.7 cm ground clearance
ป Available in Sage Green
SPORTSMAN 500 H.O.
NEW! Integratedfront storage with 6.5 gal/24.6 liter capacity, a 21% increase in volume vs. Model Year 2011 front box
499cc, high output engine
Polaris On-Demand True All-Wheel Drive
1225 lb/557.7 kg towing
180 lb/81.6 kg rear rack capacity, 90 lb/40.8 front rack capacity
Lock & Rideฎ capable rear rack
Lower winch mount
Carlisle 489 tires
IRS with 9.5 in/24.1 cm rear travel
MacPherson strut front suspension with 8.2 in/ 20.8 cm travel
11.25 in/28.6 cm of ground clearance
ป Available in Indy Red, Sage Green and NEW! Medium Yellow
ป NEW! Polaris Pursuit Camo Limited Edition model with electronic power steering and Kenda K590 tires
SPORTSMAN 400 H.O.
NEW! Integrated
455cc, high output engine
Improved radiator location- raised up more than 3-inches /7.6 cm and angled forward for better mud protection
Lower winch mount
Carlisle 489 tires
ป Available in Indy Red and NEW! Boardwalk Blue
SPORTSMAN TOURING 850 H.O. EPS
NEW! More power from the proven 850 Twin EFI High Output SOHC engine with dual balance shafts
NEW! 20 percent more power off the line
Huge Lock & Rideฎ front storage box that holds 8.2 gal/31 ltr.
Front mount service center for easy access and improved weight bias
Digital/analog gauge
Lock & Rideฎ rear storage box accessory (in place of Pass. Seat)
Hydraulic brakes with large discs
Dual cup holders
Lock & Ride rear storage box accessory that replaces rear seat
Lock & Rideฎ passenger handgrips-removable for 1-up operation
Comfort Ride Seat Suspension for vastly- improved passenger comfort with an additional 1 in/2.5 cm of travel
Soft, vibration-absorbing hand holds
Rolled IRS rear, Dual A-Arms with exclusive anti-kickback steering in front and standard power steering
14" cast aluminum wheels
Vibration-absorbing foot wells
Maxxisฎ Tires
Highest pulling power and towing
Highest ground clearance at 11.25 in/28.6 cm
ป Available in Boardwalk Blue and NEW! Solar Red
ป NEW! Bronze Mist Limited Edition with winch, hand guards, storage box, heated passenger grips and 489 II tires.
SPORTSMAN TOURING 550 EPS
550cc, single EFI
Dual cup holders
NEW! Lower idle RPM (1425) for smoother drive-away and operation
Dual cup holders
Maxxisฎ Tires
SPORTSMAN TOURING 500 H.O.
NEW! Integrated front storage with 6.5 gal/24.6 liter capacity, a 21% increase in volume vs. Model Year 2011 front box
500cc High Output, carbureted engine
Engine Braking System
Lock & Rideฎ rear capable rack
Lower winch mount
Aggressive design with enahnced sight lines
Carlisle 489 tires
Large backrest
Rolled IRS
IRS with 8.75 in/22.2 cm rear travel
11 in/27.9 cm ground clearance
ป Available in Indy Red and Sage Green
SCRAMBLER 500 4X4
499cc high output, 4 stroke, liquid-cooled engine
Automatic transmission
Long-travel rear suspension with 10.5 in/26.7 cm travel
ป NEW! Available in White/Sonic Blue
TRAIL BLAZER 330
330cc 4-stroke, air/oil-cooled engine
TRAIL BOSS 330
Outfitted with Lock & Rideฎ-capable steel racks
PHOENIX 200
Riders 14-years and older
196cc 4-stroke, air-cooled engine
Automatic transmission and electric start Two-wheel drive
Dual A-Arm front suspension
