2010 polaris 500 H.O idle issues - Polaris ATV Forum
post #1 of 12 (permalink) Old 08-28-2011, 10:06 AM Thread Starter
makeshift13's Avatar
Hope someone here could help me out. My buddy has a 2010 500 sportsman and the problem we are having is after riding it dies at idle. we checked the plug, air filter and tried to adjust the carb but the idle screw would not turn. so we adjusted the throttle cable and got the RPM's to 1350-1400 which is good according to the owners manual. this was all done last night , this morning he starts it and rides for awhile now the idle is at 1700 and the slightest adjustmennt of the throttle cable it dies out. only thing we havent done is take the carb apart and clean any help would be sweet. thanks in advance
MINE- 2011 polaris 800, 27in Moto Max tires, 14 in Nuke rims....more to follow
HERS - 2008 suzuki king quad 450 , snorkled , 27in GBC gators ,12 in ITP SS108 rims, offroad sound system....more to follow
makeshift13 is offline
post #2 of 12 (permalink) Old 08-29-2011, 03:54 AM
itsfit's Avatar
I know on my 08 it was hard to turn try again with idle screw and reset the throttle cable
2008 Sportsman 500 HO Polaris winch, front and rear bumpers, rear rack extender, ricochet armor
itsfit is offline
post #3 of 12 (permalink) Old 08-29-2011, 02:26 PM Thread Starter
Alright I will try that again but when I say hard to turn I mean hard I was afraid of breakingthe cable. Its the weirdest thing I never seen a Carb not adjust right but thatnks ill try again
post #4 of 12 (permalink) Old 08-29-2011, 03:35 PM
AKStew's Avatar
I agree, try again with the idle screw. It's not supposed to turn easily or it would vibrate out of adjustment. You are asking for a runaway ATV if you use the throttle cable to adjust the idle. IIRC, throttle play is 1/16" to 1/8" and the idle speed is 1200 +/-100 rpms.
Stew
2011 Sportsman 500 HO Touring: Polaris 3500 lb. Winch, Kimpex Adventure XL Trunk, 7" Passenger Foot Risers, UNI Foam Filter
2006 Sportsman 500 X2 EFI: Superwinch Terra 25 w/Synthetic Rope, Kolpin 4 gal Gas Pack, 3" Passenger Foot Risers, 3-Headlight Mod, K&N Filter
SOLD 2010 Sportsman 300: Polaris 2500 lb. Winch, Kolpin Rear Seat (for the dog), UNI Foam Filter
SOLD 2006 Sportsman 700 Twin EFI: 27" Mud-Lite XTR, Superwinch Terra 35 w/Synthetic Rope, Polaris HD Front Springs, OEM Front Bumper Guard, WES Rear Seat, Kimpex Fender Guards w/Footpegs, 3-Headlight Mod, K&N Filter, Symtec Heated Grips
AKStew is offline
post #5 of 12 (permalink) Old 09-02-2011, 10:40 AM
bakada's Avatar
Did you check the throttle position sensor up by the thumb throttle to make sure you have the right amount of cable slack? If there is not enough it will sense a stuck throttle cable and it will die at idle. You have to make sure the 2 contacts don't touch when you let off the gas and it returns to idle or it will die. It has nothing to do with the set idle speed.
04 Sportsman 700 efi black and silver, Big Gun Evo exhaust and tuner,3 light mod,reverse override,bar and thumb warmers,Moose pregressors,Black Rock wheels,Polaris(warn) winch and plow, 2 inch receiver, Filtermag.
00 Magnum 325 not very HO green, rolled, wrecked and rebuilt,heated grips and thumb warmer, Filtermag.
bakada is offline
post #6 of 12 (permalink) Old 09-02-2011, 10:54 AM
bakada's Avatar
Did you check the throttle position sensor to make sure you have the proper slack in the cable. If the slack isn't right and the 2 contacts touch it thinks you have a stuck throttle and it kills the bike when you let off the gas and it returns to idle.
Sorry for the double post. My wifi is giving me fits and I didnt know the first post went through.
bakada is offline
post #7 of 12 (permalink) Old 02-03-2014, 03:18 PM
Rob Hall's Avatar
2010 Sportsman HO, Throttle sensor position
I was having an issue with with my choke not working and once i did get the machine running it quit everytime i tried to idle. Your advise was right on, the contacts in the throttle control were touching. Easy fix, thanks.
Ice fishing on Mitchells Bay today, great weather at last but thick ice and few fish, try again tomorrow with a machine that is working the way it should.
Rob Hall is offline
post #8 of 12 (permalink) Old 02-03-2014, 03:26 PM
bakada's Avatar
Good deal. That one had me ready to tear everything apart to figure it out what was happening until some one on here told me to check the contacts. Simple easy fix.
bakada is offline
post #9 of 12 (permalink) Old 02-04-2014, 08:38 AM
InRBigness's Avatar
adjust ATC to proper specs on handle bar. It is not for idle adjustment.
Warm up the quad thoroughly and use pliers or screwdriver if you have the remote carb adjustment and adjust it there. If you don't warm it up, it will speed up when the quad is fully warmed up.
08 Sportsman 500HO
01 500HO Plow Machine
InRBigness is offline
post #10 of 12 (permalink) Old 10-13-2015, 05:02 AM
mulder65's Avatar
I hate to show my lack of knowledge about my machine, but can someone post a pic pointing to the idle adjustment screw on a 2012 Sportsman 500? I haven't had it long, and have yet to really tear into it, so don't know what's what on it yet. I hope I don't have to take too much off of it to get to the adjustment........thanks for helping this newbie, gents!!
2012 Sportsman 500 HO (with not NEARLY enough upgrades yet....)
mulder65 is offline
Kawasaki KLF250 bayou , Idle issues. Need your help. SportsmanJohn500 Around The Garage 4 08-11-2011 06:04 PM
2010 Polaris Sportsman 500 HO fan and battery issues mleger11 Polaris Sportsman 15 06-23-2011 06:31 PM
325 magnum idle issues dynodoug ATV Repair and Maintenance 1 12-12-2010 06:41 PM
First of all hello! and second having idle issues chetti ATV New Members 4 06-17-2010 07:03 PM
How to set idle 2010 550xp?? MUDDIE49 Polaris XP 13 06-07-2010 07:46 PM
