Tighten the chain? - Polaris ATV Forum
Old 10-11-2011, 08:15 PM
Hemikidd's Avatar
Member #19494
Tighten the chain?
whats up everyone i bought an 01 scrambler today an the chain seems to be a little loose how do i tighten the chain a little? please help me asap
thanx
Old 10-12-2011, 08:32 AM
Hemikidd's Avatar
Member #19494
bumppppppppp help please
Old 10-12-2011, 09:03 AM
Its easy.
Loosen the two long bolts that tighten the clamp on the rear bearing carrier.
On the bearing carrier, you will see a hex form formed into the bearing carrier housing. You will need a wrench big enough to fit.
At this point, you will notice that the the bearing carrier is egg shaped, and as you rotate it inside of the clamps, the axle moves forward and back, thus tightening or loosening the chain.
There isnt much adjustment here, so if its not enough, it means your chain is too stretched out and needs to be replaced.
Old 10-15-2011, 09:35 PM
Hemikidd's Avatar
Member #19494
thank you..
1993 polaris chain adjustment
adjust chains on 350 polaris atv
how do i adjust the chain on 170 rzr
how do you tighten a 1993 polaris sportsman chain
how to adkust chain in 1993 polaris 350
how to tighten a chain on a polaris scrambler
how to tighten a polaris atv chain
how to tighten chain on razor 170
how to tighten chain polaris 50 atv
how to tighten the chain on a 1993 polaris 350
polaris chain tightening wrench
tighten polaris atv chain
BJ slipping, can not tighten the castle nut r11 ATV Repair and Maintenance 5 03-05-2011 11:29 PM
How do you tighten a loose chain on '96 sportsman? mattam208 Polaris Sportsman 10 01-31-2011 12:11 PM
Hy-vo chain upgrade for silent chain/reverse chain 1997scrambler4x4 ATV Repair and Maintenance 2 03-10-2010 09:26 PM
