Old 12-21-2009, 07:00 PM
rider2421's Avatar
Member #2376
08 Sportsman 800 EFI Touring
Ok fellas i need some advice.I had a sputtering problem at first and i got that solved but running injector cleaner and 93 octane in it. Now i have a reverse effect. Now my idle speed is around 1600 rpms and it is getting hard to shift into gear sometimes cause of the idle speed. Would the T-Bap sensor cause the high idle speed or is there a way i can adjust the idle speed? If so where is it located?
Thanks for your help
Jon
Old 12-21-2009, 11:30 PM
Old 01-03-2010, 06:41 PM
pedals's Avatar
Member #2556
throttle cable
There is an adjustment for the throttle cable, where the cable ends and turns into the handle under the rubber liner there is a cable adjustment that lets you adjust the rpm..one way will make it rev to high the other will make it sputter and run to low. I find around 1140-1180 works good for mine, my friends runs at 1200
05 sportsman 800 throttle cable adjustment
08 sportsman 800 acceleration cable
08 sportsman touring hard to shift
09 polaris rzr idle rpms?
2008 sportsman 800 sputtering
adjusted idle, now hard to shift
high idle on polaris 800 efi
how do you adjust idle on razor 800 efi
how to adjust a polaris 800efi 2008
how to adjust idle on sportsman 800efi
idle adjustment sportsman 800 efi
polaris 2008 sportsman 800 idle rpms
polaris 800 throttle hung
polaris 800 twin idle
polaris high idle t-bap
polaris rzr 800 idle too high
sportsman 800 idle too high
sportsman efi idle rpm
