Old 11-14-2011, 05:07 PM
bezerk1's Avatar
Member #20465
Project Fire Duck: 2011 Sportsman 500 Rebuild
I've always wanted to document a project on a forum. Here is my chance, this is my story. I've been riding quads and bikes for a better part of my life, nearly a quarter century. First bike: Hodaka Dirt Squirt 80. I've spent time on a multitude of quads including Banshee's and Warriors. Next I moved on to bikes including RM's, CR,s, and the downfall of my racing career, a KTM. I've raced hare scrambles for about 8 years. In that time, I've knocked out a few first places, a few trips to the hospital, and a few championships. About 5 years ago an 87 Polaris Cyclone was given to me. I was told in hasn't been started in at least 10 years. It looked more like 20. I fixed (restored)it, and rode it for nearly 6 years. It was by far the most horrible quad I had ever ridden in my life. I was told by a Polaris dealer that it shouldn't be ridden, it should be in a museum. After I sold it, I felt like I needed another quad. That's when I purchased The Fire Duck. Fire Duck came from Geico Insurance at a very reasonable price. I want to document my rebuild. I will be asking many questions, as I expect you to ask many questions. If you have some advice to give, don't be afraid to let me know. Here are the pictures when I received the Fire Duck.
Old 11-14-2011, 05:23 PM
bezerk1's Avatar
Member #20465
As you can see, the body damage is quite extensive. Everything is covered in mud and melted plastic. I do not believe there is one salvageable plastic part on the machine except for the rear compartment. The slide in the carburetor is melted. Every hose and wire needs to be replaced. Despite the damage, the frame, tires, winch, engine, transmission, radiator, and suspension have no damage whatsoever. I wish I knew how the fire started, and what caused it. If I had to take a guess, I would say it was a leaking fuel line. I spend at least an hour cutting the tank apart to get the sending unit out. The right rear tire is flat due to a missing valve stem.
Old 11-14-2011, 05:40 PM
antoniodef's Avatar
Member #11247
Holy sheit! You are going to be building that sucker from the ground up! Hopefully you got one hell of a deal!
When you are done, you will defintely be the master of the current generation Polaris 500!
2011 Trail Boss - HIDs SOLD
Old 11-14-2011, 06:04 PM
jordaman17's Avatar
Member #13240
ditto to the above post
Old 11-14-2011, 06:58 PM
bezerk1's Avatar
Member #20465
Here you can see the engine after about an hour of wire brushing. Note in the second picture the burnt wires coming off the pickup. The engine cleaned up real nice for how burnt it was. All seals are intact with no melting. The intake valves had a little surface rust on them as did the plug. I filled the cylinder and intake with ATF and slowly rolled the crank by hand to coat everything. The crank felt smooth through several rotations with no binding or roughness. This is a big win on my part. A new wiring harness and carb are on their way. Polaris makes two different harnesses for the Sportsman 500. Anybody know the difference between them?
Old 11-14-2011, 07:07 PM
bezerk1's Avatar
Member #20465
Here you can see the chassis stripped down. I cut the wiring off the winch. The fan wires were melted, I re soldered new leads onto the fan. The handlebar controls seemed to take the brunt of the damage. My next mission is load the chassis up on a trailer and take it to the car wash for a good cleaning. I don't want all that crap in my driveway. I also have to put a new stem in the right rear tire so I can easily roll the Fire Duck around the barn. There is hardly any heat scarring on the frame rails. this is a good sign. The bars are burnt to a crisp. This machine seen a lot of mud before it burned up. This is going to take a while...
Old 11-14-2011, 07:23 PM
bezerk1's Avatar
Member #20465
Carb for sale. Only 250 miles on it. Slide sticks a little bit. The slide must be made out of some kind of polymer. Nothing is deformed except for the slide. The floats are completely missing, only the needle valve, and its actuator remain. The float bowl drain is gone too.
Old 11-15-2011, 03:48 AM
what year is it, Id guess from the damage on front of machine that it was one that the ecm malfunctioned , that was what the recall was about, the fan would come on by itself, wiring would get hot and start fire
Old 11-15-2011, 04:31 AM
bgirard420's Avatar
Member #11494
It's a 2011 according to the title of the post. To the OP, good luck with the rebuild it looks like a ton of fun.
2010 Sportsman 500 H.O.
Old 11-15-2011, 05:29 AM
SMP63's Avatar
Member #13545
One is for the carb models & the other is for the 500 EFI Forest Tractor Intl..
You have one heck of a project bike!!!!!!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
01 sportsman 500 front diff rebuild
98 sportsman 500 engine rebuild master kit
ac voltage or dc voltage on polaris coil
are the blue heat marks on cv joints normal?
engine rebuild on polairs sportsman 500
fire duck polaris
fire duck polarise
how many hours before a rebuild on a sportsman 500
how to rebuild polaris 500 sportsman
polaris fire duck
polaris sportsman 500 engine rebuild
polaris sportsman 500 throttle cable routing pictures
polaris sportsman forum
project fire duck
proper routing of throttle cable on sportsman 500
rebuild kit 2011 polaris sportsman 500
rebuild polaris sportsman 500
rebuilding polaris 500 ho
sportsman engine rebuild
throttle kits for polaris sportsman 500
06 sportsman 500 will not fire usaf042886 ATV Repair and Maintenance 5 03-22-2012 09:19 PM
2011 Sportsman 500 HO CV Rebuild Kit?? mlavigne88 Polaris Sportsman 1 06-15-2011 10:31 AM
Sportsman 90, No fire after welding job Bilbo ATV Repair and Maintenance 3 05-31-2011 08:34 AM
98 sportsman restoration project Drew Werner Polaris Sportsman 5 04-30-2011 07:51 AM
sportsman 500 no fire farmboy876 ATV Repair and Maintenance 3 05-18-2009 11:45 AM
