Grinding when starting - Polaris ATV Forum
Old 11-14-2011, 07:16 PM
sttucker's Avatar
Member #20459
Hi My 99 sportsman 500 makes a bad grinding sound when i am starting it cold. If i just tap the button up a few times (dont hold it up) it seems to stop doing it and starts fine. once it is warm it does not do it. A friend told me it could be water freezing in the recoil housing. It has been cold but I dont think every time it has happened it could have been froze. Also the recoil does not work. Pulls out and goes back in but never catches. Could the bendix be causing this. I hope to pull the cover off and see whats going on later in the week. Just was wondering if anyone has had similar problems and what you did to fix it.
Thank you for your help.
Also I just bought it so I do not know if it spent a lot of time in deep water.
Old 11-14-2011, 09:37 PM
Old 11-16-2011, 07:04 PM
sttucker's Avatar
Member #20459
Well I got the pull start working. That plastic wheel that the rope winds around was a lot more money then I would have thought. The bendix seemed to work ok. Not sure if its oem or after market. Does any one know what the oem ones have on them for a marking.
Old 11-16-2011, 08:22 PM
sp50098's Avatar
Member #9372
i have the same issue on my 99 500, the noise comes from under the clutch cover, i opened it up last winter and couldnt see anything, but then again i dont ahve a clue what to look for, i was expecting to find a fray on a belt or something....for some reason when its warm... its quite!
Old 11-23-2011, 02:49 PM
sttucker's Avatar
Member #20459
Thank you all for the overwhelming amount of help.
Old 11-23-2011, 02:52 PM
sp50098's Avatar
Member #9372
sounds like we have a simlilar issue i see your not gettting much help, i wont have time to tear into mine for about a month till winter really sets in hopefully someone can give you some advice...i'm thinking its to do with clutching.
Old 11-23-2011, 05:25 PM
while you had recoil off did you clean and lube bendix, you can see whats makin noise with recoil housing off
Old 11-26-2011, 03:39 PM
sttucker's Avatar
Member #20459
I replaced the bendix and it is starting great now. I got pull and electric start now. Very happy
99 polaris sportsman bendix grinds
atv starter makes alot of noise after it starts
bad grinding noise when starting polaris
grinding noise when starting quad
my atv is making a grinding sound around pull rope
my polaris makes a grinding sound while starting
my quad is grinding when i try the electric start
polaris clutch housing 99 sportsman 500 noisy clutch housing
polaris sportsman 850 noisy when starting cold
polaris sportsman grinding while starting
polaris sportsman starter grinding
sportsman 500 just grind when starting
ADC Grinding need help bobx2 Polaris Sportsman 9 08-01-2013 05:37 AM
Grinding sound when starting a 99 sportsman 500 sttucker ATV New Members 1 11-14-2011 09:40 PM
ADC grinding xp Problem..Need help BRD ATV Repair and Maintenance 1 11-09-2011 04:14 PM
grinding noise roberts46 ATV General Discussion 2 09-19-2010 01:40 AM
96 400 4x4 grinding noise l-rod Polaris Sportsman 4 06-01-2009 07:01 AM
