12-11-2011, 03:13 PM
Member #21287
Probably a dumb question..
When I first fire up my 700, there is a wrench blinking on the dash for a few minutes then the icon shuts off, and never comes back on. what does this mean?
04 Camo Sportsman 700 carb. Warn winch, 52" plow
12-11-2011, 03:19 PM
Member #20124
Not sure on yours, but on my '11 850xp the wrench means it's time to do a oil/fluid change.
12-11-2011, 03:28 PM
Member #13240
it's a service reminder, reminding you to do oil changes, it can be reset in diagnostics or shut off if you just want to keep track by yourself.
12-11-2011, 03:39 PM
Member #21287
a service reminder makes sense! how can i reset the service icon?
12-11-2011, 03:42 PM
Member #13981
Service interval time
vulcan700,Mike here.The wrench icon is a RESETABLE service interval.I reset mine everytime I change the oil and filter and do a complete service check of all fluids and grease it. You can change it to ever how many hours you prefer.It is set at the factory at 50 hours.If after say 50 hours you change the oil and filter and check everything and all is ok you reset it to say 150 hours to do it again at 150 hours you set it to 150 hours.When it has run OR the key has been left on for a total of 150 hours the wrench icon will apear again telling you it's time to do a service again.The icon will remain OFF till it reaches 150 hours and so on.Each time you reset it ,you run the hours up to your next reset interval.Hopes this helps.Mike
12-11-2011, 04:23 PM
Member #21287
Mike, thats great info thanks! but how do i reset it?
12-11-2011, 04:39 PM
Member #15215
Hold your over ride button. Turn the key on while holding the button (dont start it just turn it) Hold until you get to diagnostics on your pod display. Scroll to maint. set your reminder for increments of 50 hours or just shut it off. I just shut mine off. I do checkups often. Keeping an eye on your oil, tranny fluid, diffs front/rear coolant, and airfilter are easy to do. That wrench can get annoying so i just shut mine off all together.
2005 Polaris Sportsman 700 Twin - Green -
27" Bear Claws StI HD alloy rims
Uni air filter
Kolpin rear Storage w/cooler
Front Brushguard
Rear Brushguard
3 Headlight Mod
2up Footpegs
Pure Polaris Handguards
Stage 1 Dynojet kit
1998 Kawasaki Bayou 220 Yard mule
2008 polaris sportsman 500 ho service interval screen
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Dumb question
Rossi |
ATV Performance Modifications |
3 |
07-23-2011 05:03 PM |
dumb question
cooltoyz |
ATV Repair and Maintenance |
1 |
05-07-2011 07:20 PM |
dumb question
popo7 |
Polaris Sportsman |
4 |
05-04-2011 06:26 PM |
dumb question..... maybe?
MNPolaris850XPeps |
4 |
04-11-2011 07:43 PM |
dumb Question here
dragon001 |
6 |
11-18-2009 03:23 AM |
