Old 12-12-2011, 06:50 PM
cjr's Avatar
cjr cjr is offline
Member #17374
2008 sportsman 500 h.o differential
My awd stop working so I check all the wires and everything else and all was good. So tonight I pulled out the front diff and take it apart. Everything is good but the cage. Bears are good and plates are good. The cage is split and broken. I was thinking just to replace the cage. Since everything else look good. What do everyone else think about that?
Old 12-13-2011, 04:06 AM
can get parts cheaper from john deer dealer
Roller kit # MIA 10666
Cage KIt#MIA 10667
seal Kit #MIA10654
Armature Plate #MIA10656
Trust bearing and washer #Mia 10663
Old 12-13-2011, 06:51 AM
lost cause's Avatar
Member #9763
I would replace the cage as well as the armature plate. The armature plate is cheap enough so just go ahead and replace it while you are in there. Only thing to tell you is to make sure you get all the broken peices out before you put it back together. Also, you could look here, and you won't have to worry about your cage breaking again.
POLARIS RZR/Ranger/Sportsman SPRAGUE CARRIER / FRONT ROLLER CAGE #550 : Polaris : RZR : RZR Accessories
Polaris RZR / RANGER / SPORTSMAN Armature Plate : Polaris : RZR : RZR Accessories
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
2006 polaris sportsman 500 sprague carrier cage
2006 sportsman 500 front chunk
2008 polaris sportsman 500 efi
2008 polaris sportsman 500 front differential kit
2008 polaris sportsman 500 roller cage
2008 polaris sportsman roller cage john deere
2008 sportsman 500 rear diff
2009 sportsman 500 ho differential for sale
2010 sportsman 500 front differential seal kit
billet roller cage for sportsman 500
differential wires on 07 polaris sportsman 500
front chunk for a 07 polaris sportsman
front roller cage for 2008 polaris sportsman 500
jd part # roller kit #mia 10666 cage kit #mia 10667 seal kit #mia 10654
mia 10654
polaris front diff roller kit
polaris sportsman 500 broken roller cage
polarisatv diferential
rebuild differential kit on a 08 sportsman 500
2008 sportsman front differential!! cjr ATV Wheels & Tires 0 12-12-2011 06:48 PM
2008 Sportsman 500 EFI - Front Differential Polaris500 2011 ATV Repair and Maintenance 7 12-08-2011 06:22 PM
Sportsman 700 front differential zentar ATV Repair and Maintenance 1 10-07-2010 04:35 PM
2006 Sportsman 450 Front Differential OutsideImprovements ATV Repair and Maintenance 2 08-16-2010 11:10 AM
02-05 500 or 700 sportsman front Differential darin ATV Parts for Sale 1 07-12-2010 07:21 PM
