12-16-2011, 10:49 AM
Member #21421
Rubber snow plow deflectors...
I am new to this forum. I just purchased my Polaris 550 about 3 weeks ago. I bought the Glacier II plow with it and I am now looking for a rubber snow deflector to put on it. I am trying to keep the price down on this. Do any of you have any ideas on what I could use or where I could make the purchase.
12-16-2011, 01:00 PM
Member #9833
I used and old conveyor belt a local quarry was throwing out. I then cut it 6" wide and mounted it to the top of the plow with bolts and fender washers. The whole thing cost five bucks and works great, hope this helps.
12-16-2011, 03:51 PM
Member #20739
rubber mat from lowe, home depot, ace, true value?
2011 sportsman 550 EFI
-heated grips
-polaris 2500# winch
-AcerBis uniko atv handguards
-moose 48" plow
12-16-2011, 05:12 PM
Member #16252
Buy a large truck mudflap and cut to fit
1998 Xplorer 300-Stock
12-16-2011, 06:02 PM
Member #21250
If you are going to make it yourself, you are going to also need a piece of steel to bolt it to your blade.
And some nuts and bolts. Nine 5/16 carriage bolts, 5/16 washers, and 5/16 acorn nuts (or cap nuts, whatever they are called).
I got mine at the Polaris dealer. It wasn't that much money and it had everything in it. The part number is: 2872007 for the 60" blade.
atv snow plow deflector, glacier plow rubber, glacier plow rubber deflector, glacier plow snow deflector, glacier snow plow rubber deflector, mounting a snow deflector on an atv plow, polaris atv snow plow glacier, polaris glacier plow snow deflectors, polaris rubber snow deflector, polaris snowplow rubber, rubber top for polaris glacier plow, side deflector for atv plow, snow deflector glacier iii, snow plow deflector, snow plow deflectors, snow plow rubber deflector for atv plow, snowplow deflectors
