Old 12-17-2011, 06:27 AM
xFuzzyInlinex's Avatar
Member #18057
Question do i need a clutch kit?
Okay, so i have the new 2o11 Polaris xp eps pearl white 55o... just added 29.5 outlaw 2's to em, it looks amazing.... everything else is stock... i do not go mudding all the time, but when i do, it can get pretty thick... now i dont much about atv's, but i hear people saying i might need a clutch kit... do i need a clutch kit? whats it do for me, and how do i use it?
Old 12-17-2011, 09:34 AM
Tkdakota's Avatar
Member #16865
I would say yes you do. It cuts down on belt slippage and gets your low end back. I just ordered mine from QSC. Don't have it yet but waiting on it.
Old 12-18-2011, 02:21 PM
jp850xp's Avatar
Member #21322
does anyone know if clutch kits void a warrenty? what is normal cost for dealer to install a kit?
Old 12-18-2011, 03:53 PM
Tkdakota's Avatar
Member #16865
Not sure if it voids the warranty, but I'd bet yes it would. Really they aren't that difficult to do yourself. I'd do it myself before paying the dealer.
Old 12-18-2011, 04:24 PM
Member #18057
But still, does anybody think i need one... and what does it do and how do you work one? New boot here, need helpppp...
Old 12-18-2011, 05:23 PM
racer37l's Avatar
Member #5629
I would contact the clutch manufacturers that you are interested in. They will help you with your decision as to if you will need a kit and recommend a kit for your needs and riding style.
Con
Old 12-19-2011, 07:32 AM
lost cause's Avatar
Member #9763
You do not necessarily need one. I would recommend that you get one, but as long as you use low gear when pushing/pulling or when going through mud, you will be fine. I have run 29.5's on all my machines without a clutch kit.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
do i need a clutch kit polaris sportsman 800 27
how does a clutch kit work on a atv
how to tell if i need a new clutch on polaris sportsman 800
polaris sportsman clutch kits what does it do
polaris what does a clutch kit do
what does a clutch kit do for a atv
what does atv clutch kit do
when does an atv need a clutch kit
Clutch or Clutch spring upgrade help!!! eazytony27 Polaris Scrambler 3 04-11-2012 09:55 PM
93 350L Drive Clutch and Driven Clutch Removal dpherll ATV General Discussion 1 11-24-2011 06:05 AM
having clutch problems wonder if its due to big tires or clutch wear HELP johnnypolaris500ho ATV Wheels & Tires 8 04-03-2011 07:17 PM
Primary clutch squeak after installing clutch kit x omerta x Polaris Sportsman 20 08-10-2010 01:46 PM
