12-18-2011, 02:48 PM
Member #21471
2002 Sportsman 700..
I just bought a sportsman 700 with 1400 miles on it. It's in really nice shape. Lots of extra's as well. I am having a little trouble keeping it running. First thing I noticed is there was no coolant in the tank, the battery was pretty low and the gas is probably worthless.. Anything else to check.. Maybe replace the plugs?
12-19-2011, 11:18 AM
Member #21471
Well I went through the machine today. Topped off the coolant, added air to tires, charged the battery, filled it with fresh gas and removed the Quadrax rear seat and foot pegs and took it for a little ride, (18F degrees here today).. drove nice, not bad for 2 grand..
12-19-2011, 01:17 PM
Member #18006
Sounds like a good find. I will always recommend changing plugs, coolant, oil, fuel filter, gearcase lube and diff lubes as well as checking the belt. A good once over let's you get to know your new machine and sets a baseline for when you need your subsequent maintenance checks. But them I'm kinda neurotic about the maintenance stuff. Either way play safe, have fun, and welcome to the board.
2004.5 Sportsman 700 EFI
2007 Sportsman 700 EFI
12-19-2011, 01:40 PM
Member #21471
Thank you and you read my mind..
12-19-2011, 01:47 PM
Member #18609
That's an 02!!?? Looks great! You considering selling the rear peg system that you took off? If so I'm looking to buy!
Look at the weeper valve in the water pump, if thats leaking coolant its likely that the mechanical seal in it is bad. If its still running crappy, the carb boot might have a small tear, they are know to tear on these quads quite easily.
12-19-2011, 01:48 PM
Member #21471
As a matter of fact I'm am..
12-19-2011, 01:52 PM
Member #18609
Nice. Send me a picture or two and name your price. THANKS! You selling the quadrax box as well. Not really interested in that but just wondering.
12-19-2011, 01:54 PM
Member #21471
Ya the whole thing is going..
12-20-2011, 04:22 AM
run some seafoam in it for awhile , it will help clean up the fuel system, 1 to 2 ounces per gallon
2002 polaris sportsman 700 fuel filter location, 2002 sportsman 700 fuel pump, glacier 1 plow for 2002 sportsman 700, how to change fuel filter on polaris sportsman 700, polaris sportsman 700 fuel pump weak, polaris sportsman 700 lube
