Old 12-18-2011, 03:08 PM
jordaman17's Avatar
Member #13240
Question belt question
so on take off my 4 wheeler doesn't get up in speed to quickly but rpms are a bit high, then at about 30 km/h it feels like the belt catch's and it operates fine, is this my belt worn thin? or something clutch wise? i have the stock belt with 3300km s.
Old 12-20-2011, 11:13 AM
jordaman17's Avatar
Member #13240
ook.. since no one can help i'll just get a new belt and see what happens.
Old 12-20-2011, 02:22 PM
Kevcules's Avatar
Member #14887
Sometimes it takes awhile to get an answer, wait and it will come...
It does sound like your belt is slipping. It's probably very dirty with belt dust in there. Have you ever removed the cover and cleaned it yet? Not sure how old your bike is but I have an 01 with 3500 "miles". (I thought all Polaris models were in miles) and I had to change the belt as it was very worn (thin), I have other issues also like "creeping" ahead ,but anyways... Change the belt , do a thorough cleaning with compressed air and you should be Ok. (check you tube for information on dressing and checking your sheaves, even changing the belt ,it's easy)
One other issue mine has that I guess is quite common is the lower front engine mount wears out and lets the engine move around a little throwing off the clutch belt pulleys alignment. You might want to look at this too while your in "repair" mode.Take a long bar and try to lift the engine at the mount, if you see the mount start to separate , time to replace. If you change it yourself it's only $25
Good luck....
Kevin
Old 12-20-2011, 03:23 PM
check ramp buttons in secondary clutch while you have it apart
Old 12-20-2011, 03:27 PM
jordaman17's Avatar
Member #13240
it can be changed in diagnostics between km and miles. thanks for the help.
2004 polaris drive clutch problems
belt wearing out question nlitend1 Polaris XP 2 11-21-2011 04:31 AM
Bad Belt question Rshideler Polaris Sportsman 2 10-05-2011 10:44 AM
Drive belt question? cletus600twin Polaris Sportsman 3 08-13-2011 07:01 PM
Quick question on belt replacement Dbez1 ATV General Discussion 4 07-07-2011 10:06 AM
Carb and drive belt question. NotQuik ATV Repair and Maintenance 17 08-18-2010 10:21 AM
