12-19-2011, 06:34 PM
Member #21322
Tire size on stock 11' 850xp
What are the biggest size tires that will fit under a 850 without a lift?
12-20-2011, 06:58 AM
Member #9763
I have seen 31's with shocks turned up and a little bit of rubbing. 29.5's is the largest I would go without a lift though.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
12-20-2011, 03:36 PM
Member #18057
i have a stock 55o, the same build as you, and i just now stuck 29.5 Outlaw 2's... the mud grips are freaking ridiculous huge, and i dont rub, but its close... i wouldnt go noooo bigger than the 29.5's... even with the 29.5's, you have to worry about kicking up sticks and rocks into the fender, so definitely no bigger...
12-20-2011, 03:40 PM
Member #18057
These are the pics of the 29.5 outlaw 2's on stock 55o eps...
12-20-2011, 07:35 PM
Member #13764
Mods
Did you have to do any other mods to the bike when you put on the 29.5s? Such as a clutch kit? I have an '09 850XP and am looking at putting on a set of 27s but am being told that the larger size will rob performance. Have you experienced this?
Thanks!
12-21-2011, 03:44 PM
Member #18057
i havent had any extra mods or anything put on... no clutch kit or anything... i just got them, and havent had a chance to take it out into the mud pits yet, but i do hear that it decreases the back end power, which i why i am considering a clutch kit... but as far as riding it just around, no i havent noticed any change... ive ridden just down some trails and ditches, and noticed no change... i love the 29.5's... but to answer your question, no i have no extra mods, and no havent noticed any change yet...
12-26-2011, 03:55 PM
Member #15460
I have Dominator 28.5x12-14" in all 4 corners on MSA diesel wheels and spring in softest possision. On landing I get a little rubbing in front thats all.
850XP EPS 2011 Maxxis Zilla 4x 28x11-14" / Tatou 4S
12-26-2011, 04:37 PM
Member #19003
I have 30" Zilla's 9" fronts 11" rears. They barely touched the rear footwell flare. No need to trim, the tires made it perfect.
09 850xp
30" Zillas Blk 212's
2011 polaris 850 stock tire size, 850 xp 29.5, 850 xp biggest tire size, best atv tire for 850xp, biggest tire on polaris 850 xp, custom polaris sportsman 850 xp lifted, largest size tire for stock 850 xp, largest tire for 2011 polaris 850 xp, largest tire on 850xp eps, largest tire under stock polaris 850xp, lifted polaris 850 xp, polaris 850 tire options, polaris 850 xp foroum, polaris 850 xp mud tire sizes, polaris 850 xp tires, tallest tire on stock 2012 850xp, tire size 850 xp, tire size of a stock 10' polaris 850 xp, what ia the biggest tire to put on a 2011 polaris 850 xp without a lift, what is the stock wheel size of polaris 850 xp
