A and B are just vent tubes that vent up under the seatC looks like the tranny vent and the other green tube with gas in it is probably off the bottom of carb, carb over flow, I would suspect the needle and seat, also called float valve is bad in the carb , allowing the gas to run right through carb, might just have some debri in it and need a good cleanin but I doubt it, if you shut the gas off when its not runnin it will stop leaking on the floor but wont solve the problem, check air box and filter and see if its gassy
