Old 12-21-2011, 03:00 PM
dalem's Avatar
Member #21545
rzr 800 won't start
there are 2 wires going to the starter solenoid are both of the wires to be hot or is one a ground
Old 12-21-2011, 03:36 PM
The battery side will always be hot, the starter side will be hot when you turn the key. Think of the solenoid as a simple switch. All its doing is allowing the positive connection of the battery flow through it and on to the starter. When you let go of the key, it kills the power so the starter stops turning over.
Old 12-21-2011, 04:30 PM
Old 12-22-2011, 04:31 AM
dalem's Avatar
Member #21545
i mean the 2 small wires. not the battery cable and the starter wire
Old 12-22-2011, 04:50 AM
tt425's Avatar
Member #3687
If they are hot wires they might not be hot until the key is in the start position. You might could look at a parts diagram at babbittsonline and see. I would look but you didn't state the year model.
2008 razor polaris won't start turns over once
2011 polaris rzr starter
2011 polaris rzr wont start
hotwire polaris rzr
how to hot wire a polaris rzr
how to hot wire a rzr
how to hotwire a rzr
polaris 800 rzr will not start
polaris rzr just clicks
polaris rzr not starting
polaris rzr won't start
polaris rzr wont start battery full
replacement solenoid for polaris rzr
rzr 800 no start
rzr 800 starter
rzr 800 wont start
rzr location starter solenoid
rzr will not start
rzr wont start
No start modelaman Polaris Magnum 60 12-01-2011 11:44 AM
2006 outlaw wont start when cold but will start when warm. heavyritefoot Polaris Outlaw 6 05-09-2011 01:42 PM
Wont start from a cold start. gramslam05 ATV Repair and Maintenance 5 11-28-2010 05:57 PM
No Start fifty Polaris Trail Blazer 1 11-18-2009 12:05 PM
Phoenix won't start with start button Dodgeboy Polaris Phoenix 1 10-19-2009 07:17 PM
