Old 12-25-2011, 08:27 AM
carterjustice's Avatar
Member #21641
Polaris 800 Crew - NEED HELP!
Hello All,
I have a new 2011 Polaris EPS Crew and it has huge problems. You can ride the crew for a while and when it heats up to around 207, kill it, then it will not start. It just sits and turns over. After it sits awhile, it will start. Dealer has had it 3 different times keeping it for up to 1 month and cant figure it out. I need help!!! Now, it started a clicking noise from the left rear tire then it wont move in turf mode, only 4X4. It is like the lefts side wont pull.
Please give me ideas. My kids love this thing, but it wont work right.
Old 12-25-2011, 03:03 PM
Old 12-25-2011, 06:21 PM
shui5612's Avatar
Member #19703
i might not know much about rangers yet... but im guessing you are having electrical problems...
check all connections and put grease on them (di-electric)
as for the vehicle not going into turf../not working in turf
check the wires going to the rear dif....
also check with your dealer.... it sounds like your vehicle might be a lemon... and you could try to get a new one under warrenty... if not ... make polaris take it... and maybe add afew dollars ( might be from afew hundred to 1-1.5 thousand dollars) and get a new one...
in the worst case you will need to buy a new rear dif. , fan for cooling and all sort of sensors/electrical related things that will run up very high in cost and very fast....
hope i helped... even though it wasnt much... its all i can do..
2007 800EFI X2 Deluxe
-polaris 2500# winch
-tool grips
-VIP air windshield
-safety flag (polaris)
-Glacier II plow system
-front hitch
-1700KM
2010 850 XP EPS
- 2500# polaris winch
- VIP air windshield
-498KM
Old 12-26-2011, 10:01 AM
Member #21641
Thank you Shui- THe problem is, I cannot talk to anyone at polaris, only customer service represenatives that say, take it to a dealer. Even the dealer says it could be a lemon. Do you know how to get in touch with the right people at Polaris? Your help is gratly appreciated!
Old 12-26-2011, 01:48 PM
shui5612's Avatar
Member #19703
sadly i do not know much about how to contact polaris but might need to soon...
so im learning from the thread aswell... hopefully you will share how you are getting along with polaris.....
has the dealer tried to contact polaris? he should be doing it for you... it gives him money... ( he will "sell" another ranger and send back the one you had)
hopefully things work out for you... soon...
-tool grips
-VIP air windshield
-front hitch
-1700KM
2010 850 XP EPS
-498KM
Old 12-26-2011, 04:28 PM
get everything documented and take it to another dealer the first issue sounds like fuel pump, when it wont start have them check fuel pressure, the second issue sounds like rear diff problems, maybe just selenoid for turf mode
2010 polaris ranger crew lift kit
2011 polaris ranger not starting hot
2012 polaris ranger 800 problems
2012 polaris ranger crew 800 problems
2012 polaris ranger not starting when hot
bought a polaris 500 crew that is a lemon who do i need to contact about it
how much does a fuel pump cost for a 2011 polaris ranger 800
how much does a polaris 800 cres cost
how much does power steering cost on 2012 polaris crew 800
polaris 800 crew ranger problems
polaris atv power steering not working
polaris crew 800 problems
polaris crew power steering problems
polaris crew problems
polaris ranger 800 crew problems
polaris ranger crew problems
polaris ranger crew steering problems
polaris ranger steering problems
put lift kit on ranger crew 800 2011 not when hot
ranger 800 hot start problem
2011 Ranger Crew 800 Camo w/ EPS- Fair Price? pafsafsa ATV Purchasing and Price 2 07-22-2011 07:18 PM
New Ranger 500 crew! PawPaw ATV General Discussion 2 10-24-2010 05:56 AM
2010 Crew Lift Kit? wadester ATV General Discussion 3 10-18-2010 11:13 AM
Ranger Crew front drive Question bowfishing101 ATV Repair and Maintenance 1 07-07-2010 08:24 PM
Ranger Crew Gear Box Not Shifting When Hot! Tombstone ATV Repair and Maintenance 9 09-21-2009 05:04 AM
