Old 12-26-2011, 05:30 AM
aeresman's Avatar
Member #21654
Help!!!!!!!!
i have a 2008 500 x2 efi and its been at the dealer for 2 months and they dont know whats wrong with it. the problem started when i was riding in the woods and the machine just shut off and would not start again. i changed the battery checked fuel filter, then i thought it was something with the ignition so i changed out the ignition. still wouldnt start, my dealer states that the machine is not throwing any codes, they sent the map from the ecm and the polaris tech said that it was the coil. the coil was changed and still wont run. the dealer then switched out the ecm, and tested the spark, test the fuel pressure and still has no idea why this is not starting and run. the machine barely has 30 hrs on it. what should i do? polaris consumer service does not help with anything, i stuck in a rock and a hard place. PLEASE HELP
Old 12-26-2011, 12:20 PM
shui5612's Avatar
Member #19703
hmm.... have they tried to bypass the cluster?
and also... check the wires... might be something as easy as faulty ground or a loose wire here and there....
is it at your place or at the dealer?
might also be a loose connection.....
seeing how things are, a cable might look ok but might have been broken inside... that same problem happened with my old car... a power wire was shot and only worked with the door open (power windows) after the stealer replaced fuses, fuse box... switch... electrical motor.... i was the only one to suggest a wire change ( hell it was the cheapest thing they did @ 150$) they laughed.. but after everything and i mean EVERYTHING was changed out they replaced the wires and it worked.....
just goes to show that it might be the smallest thing that seems impossible...
they should look for rust... and check connections if they have contacts or not...
not much help... but its better than nothing right?
hope i helped....
2007 800EFI X2 Deluxe
-polaris 2500# winch
-tool grips
-VIP air windshield
-safety flag (polaris)
-Glacier II plow system
-front hitch
-1700KM
2010 850 XP EPS
- 2500# polaris winch
- VIP air windshield
-498KM
Old 12-26-2011, 04:29 PM
Kong's Avatar
Member #19350
Take it to another dealer.
<a href=http://i283.photobucket.com/albums/kk293/luv2eather/Sigs/Kongsig3.png target=_blank>http://i283.photobucket.com/albums/k...s/Kongsig3.png</a>
polaris atv
