Old 01-01-2012, 03:15 PM
lansing0713's Avatar
Member #21525
Only issue with my Guru bumper.
I recently installed a Guru bumper on my 2006 Polaris 800. No doubt in my mind this is the best bumper on the market, except this one problem. My issue is that my cable from my winch is going to rub the hell out of one of the crossmembers of the bumper. I can only imagine that I will rub a hole through the tube after a couple of good snow storms when I'm using my plow. The fairlead is "sunk" in to far with the new bumper and the cable doesn't clear. Trying to figure out a way to extend my fairlead about an inch in hopes that this will be enough to clear the bar. I also thought about finally buying a synthetic rope, thinking it wouldn't rub as bad, but that still will not solve the problem I have.
Old 01-01-2012, 04:11 PM
If you mean with plowing then just add a arm on the hook connection on the push tub.
Old 01-01-2012, 04:17 PM
antoniodef's Avatar
Member #11247
You got a picture of that Thor? I'm not understanding.
Sent from my SCH-I510 using Tapatalk
2011 Trail Boss - HIDs SOLD
Old 01-01-2012, 04:38 PM
This is the only pic I have.
Old 01-01-2012, 05:45 PM
Member #21525
Thor,
I'm not sure what you mean? I attached two pictures to maybe help.
Old 01-01-2012, 05:50 PM
Member #21525
If you are talking about welding a hook on the back of my plow, I would rather not have to do that. I was hoping to find a different solution if you got any??
Old 01-01-2012, 05:52 PM
Just drill a hole closer to the blade and add a eye hook.
Old 01-01-2012, 06:18 PM
antoniodef's Avatar
Member #11247
I get it now...thanks
Old 01-01-2012, 06:24 PM
vortecz71wv's Avatar
Member #14032
WOW....that sucks! I can't really help you in terms of showing you how to fabricate something. But I have a couple of ideas....as for extending the fairlead...you are going to create stress on it if you plan on keeping the extension on during the summer months and getting stuck...could cause you to break the cable....but just for plowing it would work with some aluminum plate cut to shape of the mounts and getting longer bolts for the fairlead.
AS for the plow mod...yea I wouldnt drill mine because of plowing dirt and gravel and so forth...but If you could get some 1/4" thick steel plate lets say 4" wide and 3' overall in length, cut it down the allow for proper lifting and somehow bolt it into the existing lift hole for easy removal if need be.
Try the fairlead spacer first...gonna have to see about getting it made at a machine shop unless you hae access to the tools. Shouldn't be more than 30 bucks in my opinion.
I hope this helps....
Matt
Mine:
2011 Sportsman 800
Polaris Front Brush Guard, Polaris Rear Brush Guard, Polaris Rear Rack Extender, Polaris L&R Rear Cargo Box, Warn 2500lb winch, Winch Saver, Ricochet A-Arm Guards (www.TheATVSuperStore.com), 3-High Headlight Mod, UNI Air Filter, 26" GBC Dirt Commanders, 1" Billet Wheel Spacers (Front and Rear) HighLifter HD springs, Dalton Primary Spring O\BL, Realtree Seat custom cover
Wife's
2011 Sportsman 550XP
Polaris Front Brush Guard, Polaris Rear Brush Guards, Polaris Rear Rack Extender, 26" GBC Grim Reapers, Viper Elite 3000lbs Winch w/ wireless
Fuel It, Flog It, Feel It!
Thats what I am here for!
warn plow
The New 2011-2012 Sportsman 500/800 Guru Bumper is Now Here! Thor TheATVSuperStore.com 10 01-05-2012 04:24 PM
Guru cobra front bumper ordered! Tag.ur.it ATV Visual & Body Modifications 0 11-30-2011 05:27 AM
guru's walleyeslammer ATV Visual & Body Modifications 4 11-18-2011 09:21 PM
Guru rear bumper with Benz silencer on 550 XP asbuilt Polaris XP 12 10-30-2011 03:43 PM
'11 850 XP Ricochet and ATV-Guru Bumper utgreenhead Polaris Sportsman 9 06-12-2011 07:42 PM
