Old 01-02-2012, 02:12 PM
Kalani938's Avatar
Member #20505
Question Right side clicking noise?
This week while riding my quad I started to notice a strange sound coming from the bottom right side of the engine compartment close to where your right foot rests. It's kind of a high pitch clicking sound? You know when you start your quad and for about a second after it starts you can hear the grinding/clicking of the starter still engaged? That's kind of what it sounds like? Any ideas on what this could be? It still runs normal.
Red 2010 Polaris Sportsman 500 H.O.
ITP SS212 14" wheels with 27" Swamp Lites
K&N High Flow Air Filter
Old 01-02-2012, 04:35 PM
take recoil cver off and see if anything is wrong
Old 01-02-2012, 05:33 PM
Kalani938's Avatar
Member #20505
Would it be something obvious?
Old 01-06-2012, 08:49 PM
bakada's Avatar
Member #2821
Check the starter Bendix gear. The one in my 08 500 rattled like crazy.
Old 01-06-2012, 09:47 PM
Kalani938's Avatar
Member #20505
What causes this to happen?
Old 01-06-2012, 10:33 PM
bakada's Avatar
Member #2821
The previous owner of mine had had it in the water. If the pull handle is not seated properly on the case when the pull rope is retracted then water can get in the pull start cover. There is a drain plug on the bottom of the cover to drain any water out. It doesn't look like mine had been used. The inside of my cover and the Bendix gear had alot of corrosion on them. I'm guessing that is what caused the gear to start rattling. I replaced it and the noise stopped. I have read of others with noisy Bendix gears.
Old 01-07-2012, 06:04 AM
Kalani938's Avatar
Member #20505
I have a 2010 without a pull start.
Old 01-07-2012, 08:41 AM
bakada's Avatar
Member #2821
You still could have a noisy Bendix gear.
Old 01-07-2012, 08:55 AM
Kalani938's Avatar
Member #20505
I know, I was just saying that water didn't get in thru my pull start. I will check my gear when I get a chance. Are they hard to replace?
Old 01-07-2012, 09:03 AM
bakada's Avatar
Member #2821
The hardest part is taking the foot well out so you can take the 5 or 6 bolts out of the cover. The gear rides in between to brass bushings. One in the case and one in the cover. Don't loose the small thrust washers on either end by the bushings. The starter spins the gear which then engages the flywheel.
Not hard.
2010 polaris scrambler rattling noise from right side cover for pull rope
2012 polaris popping noise
2012 polaris sportsman clicking noise
clicking noise in rear 2012 polaris sportsman 500
polaris 500 ho ticking
polaris 500 ticking noise
polaris magnum making clicking noise by right foot
polaris sportsman 500 clicking sound
polaris sportsman making a clicking noise
polaris sportsman starter bendix still clicking
polaris sportsman starter clicking noise
popping noize in rear of polaris 500
rattling noise in 04 polaris scrambler
rattling right side polaris sportsman 500
rear axle noise 2010 polaris sportsman on pavement
recoil housing knocking polairs scrambler
sportsman 500 making a tumpping nose in motor
sportsman 500 right noise
ticking noise on polaris sportsman 700
'09 sportsman 500 clicking noise cdwladr ATV Repair and Maintenance 3 04-30-2012 04:17 PM
Clicking noise when turned off. xp850eps Polaris Sportsman 9 02-28-2011 04:34 PM
Clicking noise from rear end. gramslam05 ATV Repair and Maintenance 5 12-01-2010 02:09 AM
Clicking noise by starter bighaas ATV Repair and Maintenance 1 09-08-2010 05:57 AM
09 850xp clicking noise? Breakineven ATV Repair and Maintenance 1 08-02-2010 07:18 AM
