Old 01-04-2012, 09:52 AM
swampdonkey1982's Avatar
Member #20846
Are HD springs really necessary?
Hey Guys, been reading some older posts on the forum regarding plowing. Seems like people like to upgrade to HD springs because of the weight of the plow. I have a plow rigged up and with the weight of the plow and me (260 lbs.) the front end of my ATV only sags 2 inches. Is there really any advantage to getting HD springs with only 2 inches of sag???
Also, do you guys that plow up your air pressure at all on the front tires? Thanks.
Old 01-04-2012, 10:54 AM
AKStew's Avatar
Member #5212
The OEM springs will eventually sag 1-2" even without the plow. If all you do is plow, there should be no issues with keeping the OEM springs as long as the plow can be lifted high enough for decent clearance. If you intend to ride recreationally you will have lost 1-2" of ground clearance, your front end will nose-dive sharply when braking, and it will bottom out when hitting sharps dips in the trails.
I don't plow with my machine but the previous owner kept a plow on it all the time which made the springs sag. I thought about going with OEM replacements but when I added a 30-pound fuel container to the front I went with HD versus OEM.
I'm glad I did. The ride is only slightly stiffer and now I can ride much more aggressively on rough trails.
Since I usually have a passenger on the back of mine, I'm about to put HD springs on the back as well.
Stew
Old 01-04-2012, 12:01 PM
Trucker's Avatar
Member #21187
They are easy to install and will take the sag out of the front end. Bike looks better also.
Old 01-04-2012, 12:50 PM
Mike B's Avatar
Member #11566
I put HD springs in all four corners of my 800. I put a front mount plow on and with the added weight and fatigued springs the front end would sit bottomed out. I'm guessing your springs are newer or maybe a belly mount plow, but if it is only sagging 2 inches I would leave it alone. Some one correct me if I'm wrong, but i believe the Polaris front HD springs have a little less spring rate than EPI or High Lifters.
Old 01-04-2012, 03:04 PM
Member #20846
Yeah it is a new ATV and also a belly mount plow. I'm sure that makes a big difference.
Old 01-04-2012, 04:36 PM
cdgoodling's Avatar
Member #17410
they sell spring rubbers that go in between the coils to stiffen them up. not sure exactly what they are called, but you can add and remove them when you want to. you can add them for plowing then remove them for trail riding. seen them on ebay, the price is fairly cheap.
Old 01-04-2012, 04:41 PM
cdgoodling's Avatar
Member #17410
ok just checked ebay they are called "polaris snow plow coil spring spacer kit" cost is $20. may be worth looking into if you dont want to spend alot of money.
Old 01-04-2012, 07:49 PM
shui5612's Avatar
Member #19703
might want to get some moose progessors or something...
wont regret it and will stiffen up your suspension or free it up just by turning a dial like on your rear suspension!
Pregressor from TM2
they can stiffen and soften the suspension.
polaris sells them aswell. (about 79.99$ here)
i always leave my plow mount on (summer and winter) as i plow in the summer (level sand ) and winter (clean driveway)
it really added some stiffness that the nose doesnt dive, and i can sit 2 people on the front rack and the A-Arms are about 2" from level (240 pounds one person and 250-265pounds the other )
best part, they are adjustable, so you can have a soft ride if you want to and stiffen when you plow...
another good point about it is (lets say OEM springs are 80#) you can adjust from softest setting to 90-100-110-120 (just numbers, not sure about the real mesures) but it has 5 settings or so...
hope i helped!
2007 800EFI X2 Deluxe
-polaris 2500# winch
-tool grips
-VIP air windshield
-safety flag (polaris)
-Glacier II plow system
-front hitch
-1700KM
2010 850 XP EPS
- 2500# polaris winch
- VIP air windshield
-498KM
850 xp springs seem soft on front
850xp epi hd springs
atv plow sag
atv plow suspension sag
atv spring progessors
epi hd springs for 850xp on ebay
epi hd springs on ebay
epi polaris 850xp hd springs
polaris 850xp epi hd springs on ebay
polaris atv plow trip springs
polaris glacier 2 trip springs
polaris hd front springs
HD springs before and after Razorback ATV Brakes & Suspension 30 02-05-2012 03:37 AM
HD springs Cannedham ATV Brakes & Suspension 2 12-27-2011 03:16 PM
how can i tell the dif in springs hotairgypsy Polaris Sportsman 2 02-19-2011 10:05 PM
EPI HD Springs cityboy21 ATV Brakes & Suspension 1 02-10-2011 09:56 AM
MV7 Springs Vinnie0918 ATV Brakes & Suspension 0 06-23-2010 06:02 PM
