Originally Posted by 800touring
I payed like 150 for all the parts replaced it my self in about 1 hour. you have to take off the back plastics to get to the brake away bar then you pop of the brake a way bar then loosen the 2 bolts for the air box and move it out of the way so you can use i think a 8mm socket to loosen the top 6 bolts after that pop it off and when it off i would check the valves to make sher nothings going wrong like them being bent. pop on the new valve cover and bolt er her down and put it back together. I am 14 and did this by my self it was easy
thats so cool on you being 14 and being able to do this...
can you post the parts list?
anyone else did this if so how much did it cost you?
and still 2 unanswered questions:
- was there a bulletin on this?
and
- anyone have an instruction manual/chart on what to do ?
\kinda like a service manual...
