01-07-2012, 04:15 PM
Member #22052
not firing
hi I have a polaris sportsman 90 2001 that ran when parked due to swing arm troubles now it doesn't fire their no voltage to coil or cdi box stator has 3 wires in plug and 2 single wire they all have continuity the most acv I could get out of plug was 4 am I testing correctly and can and body provide wiring diagram and proper testing with spec
01-07-2012, 06:18 PM
Member #3687
Make sure the tether kill switch is properly seated in place. If it is test it to make sure it works properly. Make sure key switch is in the on position. Look at the small rocker switch on the left hanldle bar. Make sure it's on and working properly. Make sure the battery is fully charged. My son has the same atv and the tether is starting to mess up and work loose sometimes.
01-07-2012, 09:13 PM
01-08-2012, 08:23 AM
Member #22052
tt425 thanks for your response. I checked continuity on back of handle bar kill switch, didn't think about checking flow of current at the time. what are you referring to when you say tether?
01-08-2012, 08:27 AM
Member #3687
The safety kill switch near the key switch. It has the cord on it that has a velcro strap that attaches to the riders wrist.
01-08-2012, 12:21 PM
Member #22052
that switch has been bypassed.
01-16-2012, 09:58 PM
Member #19160
Stator Testing:
Black to:
W/R 110 +/- 20
Blk/Red 780 +/- 30
Y/R 0.5
W .06
Ground 0
Have seen many of these where just cleaning the stator and the flywheel and restting the gap has worked. You will have to pull the flywheel to accomplish though. Otherwise if its bad your in for about $130, I have 3 bad ones hanging on my work bench!
01-17-2012, 05:21 PM
Member #22052
thanks for your response onequik1
I've checked and found that I have no resistances on two wires forgot what color they were but figure I need a new stator. bidding on a new one on ebay now
01-17-2012, 08:49 PM
Member #19160
Cool, make sure you set the gap on the stator and flywheel to .020-.040". Good luck!
01 polaris 90 wiring diagram, 2000 sportsman 90 not firing, 2001 polaris scrambler 90 emergency switch bypass, 2001 polaris scrambler 90 no spark, 2001 polaris scrambler 90 not firing, 2010 sportsman 90 kill switch, 90 sportsman polaris not firing, atv not firing is it cdi or stator, bypass handlebar switches on polaris scrambler 90, how to bypass safety wires on a 2001 polaris scrambler 90, polaris 90 not firing, polaris 90 sprtsman not firing, polaris 90 wiring, polaris 90 wiring diagram, polaris scrambler 90 wiring diagram, polaris sportsman 90 not firing, polaris sportsman 90 teither wrist band, testing a tethered kill switch for continuity, what wires on stator should have fire 90 predator, why my atv not firing
